You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I;m having a hard time finding info on setting up a propane system for my truck. It's a 73 f100, 360. I want to keep the gasoline fuel system. I know that there are lots of dual fuel setups out there, I just can't find any info on them. Can anyone point me toward some books or links where I can get more info?
Get either a CA300-70 or a CA425M Mixer (And adaptors)from IMPCO They will work fairly well on or engine, I recommend the CA300 as it makes dual fuel easier. You will Need either a IMPCO Model E or a Century M6 Vaporiser, 2384B filter fuelock for LP, a gasoline lockoff and I would recomend a Dual Curve from Autoronics. There are some hoses and switches you need also and of course a tank which you might find used.
Contact your local LP dealer he should be able to order anything you need.
I sell the equipment but I cannot sell it retail you must work thru a dealer.
Any questions please give me a shout.
800-241-1971
Regards
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
Looks like the Impco 425 mounts in place of a gasoline carb- Is it normally mounted differently in dual fuel setups, or can a mixer be mounted above the gas carb in a tall air filter?
The 425 can be mounted on a throttle body for dedicated LP. for dual fuel its usally mounted on an adaptor that offsets it sideways on top of the existing card, then a filter is installed on top of the 425 horizontally
Regards
__________________
Jim England
