fuse box identification - Ford Truck Enthusiasts Forums
Old 06-25-2007, 08:58 PM
Spotty Spotty is offline
Spotty is gaining momentum as a positive member of FTE.
I went to change a license plate illumination bulb only to discover the socket had rotted away. I cut the wires off to replace the socket but forgot the power was still on. I did find the right fuse by looking at the wiring diagram in my Chiltons. Since both fuse boxes say " see owners guide" ( which I don't have) does anyone have a source where I could print out what fuse is for what. I have both the power distribution box under the hood, and the fuse panel under the driver side dash. This is on my 98 F-150. Thanks for any help.
Spotty..
Old 06-25-2007, 11:59 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Owner's manuals are available free for download from www.fleet.ford.com under MAINTENANCE.
Steve
Old 06-26-2007, 06:02 AM
Thanks Steve.... I will check that out.
Spotty..
Rear Entertainment System Failure Jarnig Explorer, Sport Trac, Mountaineer & Aviator 0 01-18-2015 02:14 PM
Wiring delimna maples01 1968-2013 Full Size Vans 6 11-02-2014 08:24 PM
FEW-14429-A cigar lighter fuse rating wjslam 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-07-2012 03:24 PM
Blowing fuse Need Help Tdraym 1999 to 2016 Super Duty 7 10-24-2011 10:22 PM
94F250 horn and cruise control problem Jim TN 1987 - 1996 F150 & Larger F-Series Trucks 8 09-04-2011 09:16 PM
Tags
2004, 97, 98, 99, block, box, drivers, f150, ford, fuse, heritage, identification, identifier, mustang, side, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
