Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Advertisement
  #1 (permalink)
Old 06-25-2007, 05:35 PM
Soilman Soilman is offline
Garage is empty, add now
Soilman is starting off with a positive reputation.
Dana 50 or 60?
OK I don't have a sure answer to my questions and I am getting ready to need to know. After 220,000 miles of hard use I finally need to speed some money on my front hubs, axle, etc. But before I spent a dollar on a DANA 50 I need to consider going to the DANA 60.
1) Do I have a DANA 50? fficeffice" />>>
Diff Tag: 4.10 1C34 KA
6110712
On front of front axle housing: 47721
On back of front axle housing: 228 003
On diff cover: 47707-1
266-00
REV-N
012599
2) Is it true the ONLY difference is internal and not external between the newer SD DANA 50 and 60? I have looked at them a little and see no big differences so is it a simple unbolt my DANA 50 and get a DANA 60 from a newer SD and bolt it in my truck? Is there a difference in the F250 or F350, I am told no?
3) I have different sources giving different answers on years. 2001 F250 MIGHT have a 60, no 2002 got the 60's, no 2005 got the 60's, they were only in the F350 after 2002????? I want to call a junk yard and ask them to sell me a hub to hub axle off a 2003 F250 that was not involved in a wreck and know I am getting a DANA 60.
4) Is the yoke to the front drive shaft different and will I need to change that? >>
5) Do I even need to upgrade to the 60, the 50 has held up this long?
I need to repair my left front hub and am getting ready to add a locker to the front so I want to consider the upgrade before I do. Thanks for any help ahead of time.>>
__________________
2001 F250 XLT SC 4x4 5.4L auto 4.10LS 200K+ miles
4" Skyjacker lift, 37x12.5x17 BFG M/T, K&N MAI, Gibson headers,
custom exhaust, Vortex muffler, Superchip tuner and more!
ONE BAD A** 5.4L THAT LIVES FOR MUD!
1977 F150 4x4 460 auto 3.55 lockers 35"-44" tires
2005 F150 XLT Crew Cab 4x4
  #2 (permalink)
Old 06-25-2007, 05:58 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
2002 and up f250, f350 and f350 DRW have the dana 60 front diff. 99-2001 f250 and f350 SRW have dana 50 front diff. 99-2001 f350 DRW have dana 60 front diff
__________________
2001 Powerstroke, CC,SB,Lariat,Auto,4X4
Mods. in Gallery
2007 Lincoln MKZ awd
http://www.ford-trucks.com/user_gall...oid=65664&.jpg
its good to have an open mind...but not so open that your brains fall out
  #3 (permalink)
Old 01-13-2009, 11:27 AM
valiant500hp's Avatar
valiant500hp valiant500hp is offline
2002 Ford F-350
valiant500hp is starting off with a positive reputation.
Quote:
I've seen this blind response in multiple threads and it isn't true. A lot of guys give that blanket response. I have a 02 F-350 SRW built in April of 02 and it has a Dana 50 front end. No, mine hasn't been wrecked and swaped or anything else.
Just a little FYI.
  #4 (permalink)
Old 01-13-2009, 02:19 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
Yep, some 02s still had the D50....not sure how long it took Ford to used up D50s and solely use D60s.
__________________
DC
2001 F-350 PSD 4x4 Hell Raiser, Heavily Modified
2007 F-350 PSD 4x4 Work Horse, Moderately Modified.
Other 2wd PSDs: 99 F-450, 00 F-450, 01 F-350, 02 F-350, 02 F-550, 04 F-450, 06 F-450
  #5 (permalink)
Old 01-13-2009, 02:25 PM
Moto52's Avatar
Moto52 Moto52 is offline
Moto52 is starting off with a positive reputation.
Is there any easy way to tell if you have a D50 or D60???
__________________
02 F250 CC SB 4x4 Lariat
Banks Exhaust, DP Tuner, autometer gauges, CCV mod,
  #6 (permalink)
Old 01-13-2009, 02:35 PM
SBastow SBastow is offline
SBastow is starting off with a positive reputation.
Is the D50 a weaker axle? Are there known problems with them?
__________________
99 F-250 4x4 Reg Cab 5.4
99 Expedition EB (gone but not forgotten)
  #7 (permalink)
Old 01-13-2009, 02:43 PM
DCSpecial's Avatar
Run the BOM number on the axle, or I believe the pinion snout on the D60 is slightly longer than the D50.
D50 inner shafts neck down to 1.31" at the splines vs. the D60 that are 1.5" throughout. Ring gear, pinion, pinion spine count etc. are all larger on the D60.
That being said, I haven't had any issues with the D50 on my lifted 01.
__________________
DC
  #8 (permalink)
Old 01-13-2009, 07:30 PM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
a Dana 50 axle will have a 50 cast into it.
a Dana 60 axle will have a 60 cast into it.
early production 2002 had Dana 50.
mid year 2002 switched to the Dana 60.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
SnowBunny for President in 2012
BabyBunny for Vice President in 2012
  #9 (permalink)
Old 01-13-2009, 07:50 PM
cparks cparks is offline
2011 Ford Explorer
My Garage
cparks is starting off with a positive reputation.
I think the DANA 50 is a good axle, but it depends what you are doing with the truck. I know when Ford came out with the IFS DANA 50 back in the 80's it was much better than the DANA 44. Sure it might not be as good as a DANA 60, but I would say 90% of the people running a Superduty don't need a DANA 60 front axle. My 2 cents for the day.
__________________
Clayton Parks - Michigan
2012 Ford Raptor SuperCrew
1957 Ford Ranchero 4x4 428 project
1960 Ford F250 4x4 521 stroker project
2011 Ford Explorer 4x4
  #10 (permalink)
Old 01-13-2009, 07:53 PM
beer boy's Avatar
beer boy beer boy is offline
beer boy is gaining momentum as a positive member of FTE.
other than the hubs, your going to have to do alot to blow up a dana 50 in these trucks.
__________________
2001 F250 psd. lariat 4x4.120000 mi. shes not quite virgin no more...6637 air filter, pyro, coolat temp, engine oil temp, boost and battery gauges. f550 center dash insert. shimmed fuel pressure. added fuel supply pump. hutch mods. mobil1 5w40 syn. coolant filter. racor fuel filter added primary. warn front hubs. oversize tires. it just keeps going...
2011 f350 6.2l x-cab 4x4 i love sync. 25000kms. service truck.
  #11 (permalink)
Old 01-13-2009, 08:27 PM
Thanks guys, it has been a while but I still have not fixed the dana 50 yet or upgraded. To answer one question, no I don't think there is a problem with the 50 in my 2001 because I have put it through hell so far and it has held up. I was just thinking before I invest money in it I should consider the 60 because I am running 44" buggers with 450+ hp!
If the pinion snout is longer than I would need to get the front drive shaft off the donor truck also, correct?
__________________
  #12 (permalink)
Old 01-13-2009, 08:47 PM
Sooper-Doodie Sooper-Doodie is offline
Sooper-Doodie is starting off with a positive reputation.
Quote:
The Dana 50 is just a Dana 44 fitted with Dana 60 outers. The axle shafts are nearly the same between the two save for a necked down portion near the carrier (which makes them completely different but, you know...) The Cover on a Dana 50 is identical to old school Dana 44 fronts and rears. A "50" is cast into the top of the case on a Dana 50.... Same goes for the Dana 60, just with a "60" cast into it.
  #13 (permalink)
Old 01-13-2009, 09:01 PM
DCSpecial's Avatar
Quote:
What is the same between the D44 and the D50?
Ring gear diameter is different and pinion shaft diameter is different.
Are you referring to the Diff Cover being indentical to a D44?
In the SD the D50 and D60 use the same cover.
__________________
DC
  #14 (permalink)
Old 01-17-2009, 05:55 PM
2011 Ford Explorer
My Garage
DANA 50 has a 9 inch Ring gear and the DANA 44 has an 8.5 inch. The DANA 50 is all around stronger, and a pretty darn good axle.
__________________
  #15 (permalink)
Old 01-17-2009, 06:48 PM
99f350sd 99f350sd is offline
99f350sd is gaining momentum as a positive member of FTE.99f350sd is gaining momentum as a positive member of FTE.
611194-2 Look for this number somewhere on the unit.. If you have a 2001 you have a D50 no doubt about it. Numbers you gave are good but you need this BOM number..
Of course if someone changed it?
Dick
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..MDII Plow, 200 amp alt timbrens,Revo's
THREE 96 aero*awd 4.0 ext. GREEN,BLUE,WHITE
2010 SUZUKI SX4 AWD CVT NICE
USAF 76-80
Tags
1999, 2002, 477077, 50, 60, 90s, axle, d50, d60, dana, duty, f250, f350, ford, sd, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
