R134 retrofit in a 79 - Ford Truck Enthusiasts Forums
Old 06-25-2007, 03:34 PM
broncman broncman is offline
broncman is starting off with a positive reputation.
I have a 79 F350 with the york compressor. I want to retrofit the AC system . What do I need to buy and what about changing the oil in the York compressor? What type and how much? Anyone have a guide to retrofitting these trucks.
I have access to gages and a vacuum pump and AC equipment.
What is the basic rundown of what is involved.
Thanks
Old 06-27-2007, 12:10 AM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
The basic rundown is:
-Flush the old oil out of the system. Disassemble and flush piece by piece.
- Drain and flush the compressor (York) with Ester oil.
- Fill the compressor crankcase to the recommended amount with Ester oil. If you look around there is a proceedure for making a dipstick for the York comperssor.
- Replace the Receiver/dryer
- Replace the expansion valve (It's 28 years old and you have to take it out to flush the evaporator).
- Replace the o-rings in all of the connections, including at the compressor. This has nothing to do with compatability, they're 28 years old.
- Ideally you would have the POA or STV recalibrated for R134a. It will work ok without this, but doing so will give the best performance.
- If the fan clutch is more than 8-10 years old, replace it with a new Motorcraft clutch.
- Evacuate the system with a vacuum pump for 40 minutes at 28-29".
- Charge with R134a, start with 80% of the recommended R12 charge.
Keep in mind that the shaft seal on the compressor could be bad. It can be replaced, but special tools are needed. You may be able to find a shop the do the seal for you.
A/C compressor question 1980Supercab 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-14-2014 09:38 AM
Replacing York AC compressor vettman 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-14-2008 07:47 AM
York or Sanden compressor tben9689 Cooling, Heating, Ventilation & A/C 3 05-19-2004 11:09 AM
York 10R or 10L compressor with SERPENTINE belt for On Board Air system????? cusdm91 Cooling, Heating, Ventilation & A/C 5 02-13-2003 01:46 AM
Is there a York compressor bracket for 390? Charles-65F350 1961 - 1966 F-100 & Larger F-Series Trucks 19 09-16-2001 10:06 PM
Tags
79, ac, change, compressor, expansion, f150, ford, pickup, r134, r134a, retrofit, retrofitting, truck, valve, york
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
