Drop Axle compatability Question
Maybe this will help.
The 46-47 Ford axle is 50-3/4" King Pin to King Pin
29" center to center spring pad 1-3/4" wide springs
Kingpin size .8125 46-47 has no shock mount holes in axle
This axle can be dropped 4" overstock
The 48-52 Ford axle is 50-3/4" King Pin to King Pin
Kingpin size .8125 48-52 has shock mount holes in axle
This axle can be dropped 3" overstock
The 53-56 Ford axle is 53-1/2" King Pin to King Pin
32-1/4" center to center spring pad 1-3/4" wide springs
Kingpin size .859 53-56 has no shock mount holes in axle
The 57-60 Ford axle is 53-1/2" King Pin to King Pin
32-1/4" center to center spring pad 2" wide springs
I know this info because I drop axles .
Ad link removed by FTE staff -- please re-read the guidelines.
Dick I'm getting ready to install a 3" Dropped Axle in my 51. I have read some not so favorable things about the Tie Rod Drops. Also I see Speedway quit carrying them. My question is who is running them and have they had any bad experiences with them. Where is the best place to purchase them. Are they all the same or is some better than the others.
I've used them a few time over the years, mostly because of the tie rod itself hitting the pan or another part of the undercarrage.
The ones that I used were reasonably well made and held up under some severe conditions inflicted on them by a speed crazed, space for brains, less then reasonable person.
I'll have to check and see who's carring them and where they're made.
kappajoe
04-29-2016 09:53 AM
hairyboxnoogle
12-07-2013 05:30 AM
REDS52F1
06-13-2013 10:12 PM
