81 Ford - Ford Truck Enthusiasts Forums
81 Ford
Old 06-25-2007, 11:57 AM
81BlackThunder 81BlackThunder is offline
81BlackThunder is starting off with a positive reputation.
81 Ford
I have a 1981 Ford F150 Trailer Edition I was wondering what kind of rear do I have in it the rear end has all the bolts towrds the front of the truck and I was wondering why my vin would say I have a 351W when my engine compartment says its a 5.8LM/6.6L and How can you tell the diff between the 351W the 351M and the 6.6L
Old 06-25-2007, 12:14 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
9 inch rear axle.
351M/400 = 8 valve cover bolts. 6 valve cover bolts = 351W
Old 06-25-2007, 02:16 PM
Thanks
Thanks for the info but how can you tell between the 351M and the 400
Old 06-26-2007, 10:48 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
If the valve cover sticker is gone, I think the only way to tell is to open the motor up. They are the same externally, the differences are in the bore and stroke. You can put a 400 crank in a 351M to make a 400.
Old 06-26-2007, 02:04 PM
zpmps2 zpmps2 is offline
zpmps2 is starting off with a positive reputation.
if you have an rpm gauge, cant that tell you guys, i think thats how i told mine was a 351M, it tach out at 5000, even thought i have the red pointer on the sunpro tack at 4500
Old 06-26-2007, 05:37 PM
jdgreen72 jdgreen72 is offline
jdgreen72 is starting off with a positive reputation.
you can crank any engine any rpm (within logic) if built right, or it can be limited anywhere, if built or runnin wrong, your diff is either a 9" or an 8.8", if you can get a socket on the bottom 2 bolts, it's a 8.8, if not, thank god it's a 9".
Old 06-26-2007, 09:32 PM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.
Just what is the 8th VIN character?
Old 06-27-2007, 10:34 PM
occupant occupant is offline
occupant is starting off with a positive reputation.
8th VIN digit of H should be a 351, S should be a 400, at least that's the way it is in the cars offered with 351 and 400 motors.
Old 06-28-2007, 10:36 AM
kc5gxl kc5gxl is offline
kc5gxl is starting off with a positive reputation.
Another way to tell the difference between a Windsor and a Modified is where the T-stat is located. The Windsor engine has it located in the intake, the Modified has no water in the intake, so the stat is located on the block.
Dan Harriman 84 F150 lwb
Orange, Texas
Old 06-28-2007, 11:36 AM
My 6th digit is an H, but anywhere else on the vin there is not another H or S, but also mine is an 80, so i can get a socket to the bottom 2 bolts, but i cant not get a socket rench in their, so i have an 9 inch right, i can only get a 9 16 rench in their, thanks guys, but my 6th is an H. So if you can clear me up.
Taylor
Old 06-28-2007, 11:47 AM
f_balla_69 f_balla_69 is offline
f_balla_69 is starting off with a positive reputation.
youve got a 9 inch if the bolts are pointing toward the front, a 351m is a big block even though it doesnt look it, the 351 windsor and 351 cleveland are small blocks, and if you have 8 valve cover bolts its a big block (351m or bigger) if it has 6 valve cover bolts its a small block (351w or 351c or smaller), how you tell if its a 351m or 400 i dunno, i thought that 351m meant 351 modified to a 400 because every sticker on the valve cover ive seen for a 351m says 351m/400
Old 06-28-2007, 11:50 AM
f_balla you are right about the 351m/400 bein' a 400 cid motor, but not all forward bolt rears are 9", ford also made a 8.8" that looks exactly like the 9, but the lowest 2 bolts are not accessible with a socket.
Old 06-28-2007, 12:00 PM
thank you for tellin me that now i know and ill try not to confuse anyone else...lol
Old 06-28-2007, 12:40 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Quote:
You are a little confused I believe. The 8.8 rear is a totally different looking rear with a sheetmetal cover on the back. It was used in trucks and cars starting in the mid 80's.
The ones that are hard to tell the difference if they are not side by side is the 8 inch rear and the 9 inch. Those are the older style rears that look the same, and you can use the socket test. They also made an oddball 9 inch in some of the cars that won't interchange. But the 8 inch and the oddball 9 inch were never used in trucks.
Can i replace a 6.6l400 with a 351w? zoobiedoo 1968-2013 Full Size Vans 2 08-10-2009 02:37 PM
msd questions? OneSweet81 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 13 08-08-2009 10:15 AM
81 f150 G=351M ?????????? or does it dpc 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 06-15-2005 02:15 PM
fuel mileage 351 81rangerF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 09-04-2004 10:07 PM
which rear end? 81rangerF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-29-2004 02:55 PM
Tags
1981, 351, 351m, 81, f150, ford, has, headers, motor, truck, vin, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
