Engine Block Casting numbers? - Ford Truck Enthusiasts Forums
Old 06-25-2007, 10:50 AM
Truckboy's Avatar
Truckboy Truckboy is offline
Truckboy is starting off with a positive reputation.
So while I have my engine out and cleaned I now see Firing Order numbers cast in the intake manifold and I see Cylinder numbers next to the associated piston. Are there any numbers on this block that will tell me anything about what type of engine it is, when it was cast, and that kind of stuff?
Old 06-25-2007, 04:21 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.
If the engine is orginial to the truck; your vin number will enable you to determine the engine size, on the side of the block near / above the starter is usually your casi ng block number. It should read something like D0AE6016C something of that effect.
Ford part number started back in the 50's; the 1st digit is the 10 year era increment ( like A=40's, B=50's, C=60's etc, the second digit is the year with that 10 year increment (D0= 1970 model. The 3rd digit is type of vehicle A= full size car, T= truck. The 4th digit indicates wheither a engine part or chassis, E= engine; C = chassis.
I hope this helps; to determine wheither its a 302 or 289 etc is alittle more challenging.
The firing order will also weed out engine types as well.
Mitch
Old 06-25-2007, 05:58 PM
Truckboy's Avatar
The intake manifold has a little tag looking thing that is cast into it that looks like it was screwed on, is far as we can tell it is 0022 or 0D22. According to the code keys this is probably 0D22 for April 22nd 1970, since there is no code key for a 0 as the second number for any of the months. As for the firing order is says on top of the manifold: FIRING ORDER 1 5 4 2 6 3 7 8.
There is also another number right under the 0D22, C8AE - 9425 which from what I can tell is 1968, Galaxie, Engine Engineering Dept. No revisions.
And now my son calls me up and tells me that there are the Letters C8AE-H in between the spark plugs. According to the info on the web that might mean that this is a 427?!?!?
There are a couple of other numbers or letters that we cannot find reference to. Right Above the 0D22 there is the number 17 and then on the sides of the block there are the letters DIF ? Can't seem to find what these mean.
Old 06-25-2007, 08:21 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
You need the engine forum not the truck forum.
The block numbers are locate just above the starter.
Those casting numbers 17 and DIF are only Ford plant Identification codes.
Engineering numbers are DESIGN NUmbers
The suffix is the change up number re: part design.
as you can see that part was designed for a 68 Large ford car (Galaxie/LTD)
was cast in April of 1970 for what ever vehicle and the part has gone through 7 changes up to 1970.
Probably the emissions outlets and things like that.
I would be pleased to continue if you ask a mod to move this to the corresponding Engine forum ..the FE forum.
427 ?
Old 06-26-2007, 09:29 AM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Engine information can go either in the engine section, or the vehicle section that covers that engine. Truckboy, its okay... you're posting in the right section.
(If something is in the wrong section, the FTE staff decides that. )
Old 06-26-2007, 08:01 PM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Look at the coil where it mounts to the manifold, there should be a metal tag attached by one of the coil mounting bolts (if it hasn't been removed over the years) and on that tag is much of the pertinant info you want. For a very good breakdown of casting numbers, look here:
http://www.classicmustang.com/decoding_part_numbers.htm
Old 06-27-2007, 11:23 AM
Truckboy's Avatar
Thanks everyone! Yea my coil is now an Accel coil and is bolted to the Firewall at the back of my engine compartment. I did find a tag on the top of the manifold that pretty much tells me that it is a 390 but the tag that is similar to that on the Heads, next to the spark plugs points to a 427. However the build up of concensus is the numbers 63 and 352 below that number on the front of the block above the oil filter, the fact that I have two bolt engine mounts, and the sides of the piston counter weights are beveled all point to a 390. I have not taken the dowl displacement measurement but I will later.
As usual THANK YOU EVERYONE! This has got to be the greatest on-line forum community that I have ever dealt with. I love the modern internet world! I can't imagine slugging through this without this site...
Old 06-27-2007, 06:16 PM
Those C8AE-H heads were used on the 1968 ...360,390,428 with thermactor.
Aside from being classed as HIgh Performance ...They are nothing special and definitely not a 427.
Old 06-27-2007, 06:26 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Sometimes...not always, you can ID the engine IF the dizzy is original...look on the base of the dizzy, below the rim of the cap. There will be a number code there like: C8AF-12127-F.
Is the dizzy a dual point distributor? Ford p/n: C0AZ-12127-L. Marked >> C5AF-12127-E.
Old 06-27-2007, 08:27 PM
Truckboy's Avatar
Nope, single point and I don't think it is the original dizzy since I was able to find a Mallory label on it.
Old 06-27-2007, 09:03 PM
You have to IDent the crank or do the stroke measurement to know for sure.
Old 06-28-2007, 12:11 PM
Truckboy's Avatar
I am going to be replacing my main bearings so where on the crank does it tell me what I need to know? or is it a measurement thing?
Old 06-28-2007, 03:17 PM
The Number is stamped on a journal.
I'll get you the numbers to look for.
EDIT:
360 = 2T,2TA
390 = 2U,3U,2UA
Old 06-28-2007, 07:06 PM
TigerDan's Avatar
You can also measure the stroke with the engine still assembled and in the truck. What I did to verify that mine actually was a 360 and not a 390 was to pull a spark plug and insert a wooden dowel into the spark plug hole till it rested on top of the piston, then turn the crank by hand while steadying the dowel and feeling for BTC. At that point, make a mark on the dowel at some reference point (like the top of the spark plug threads) and then turn the crank again which will push the dowel back up, till you find TDC (either by feel, or with the timing pointer if you're doing the #1 cylinder). Make a new mark using the same reference point as before, pull the dowel and measure the distance between the marks. This should be very close to your actual stroke. If it's a 360 you should measure 3.5 inches, if it's a 390 it'll be 3.784, which is a bit over 3-3/4".
Block casting numbers Buldog 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 03-18-2010 09:50 PM
casting numbers jacob_9249 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 07-26-2008 09:04 AM
105 cast backwards on clock pez1 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 14 06-02-2005 06:15 PM
Casting numbers rsg36 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 10-18-2004 03:49 AM
Casting numbers on engine block original67 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 05-19-2004 11:10 PM
Tags
12127, 223, block, c5af, c5af12127e, casting, codes, distributor, dual, engine, ford, number, numbers, point, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
