Replacement LED Bulbs. Do i need a voltage regulator?
I am considering replacing my standard brake light bulbs with LED bulbs. The companies selling the LED bulbs, say a voltage regulator may be necessary for correct operation of the turn signal.
Has anyone installed the LED bulbs? Did you need the volt. reg.?
Thanks bill
2006 F350 V10 4x4
Thanks bill
2006 F350 V10 4x4
I haven't heard of a "voltage regulator" being needed, but I have heard of load resistors being needed. Maybe they are calling the load resistors voltage regulators?
The problem is some of the flasher circuits in automotive equipment require the load of a regular bulb to work correctly. An LED type bulb has very little load, so to make the circuits work correctly, you wire a resistor in parallel with the LED bulbs to raise the current draw up to the standard old bulbs.
I meant load resistors.
Thanks bill
2006 F350 V10 4x4
Thanks bill
2006 F350 V10 4x4
Did anyone need to use the load resistors?
Originally Posted by Torque1st
It is better to use a HD 3 terminal flasher (check a #571 unit) or an electronic flasher unit that does not require the load from the bulbs to make it operate.
Originally Posted by Sycostang67
Thats what I did. The HD flasher stopped my indicators from coming on, until I swapped the front signals for LEDs as well. My solution to that was add more LED's. All 6 bulbs on the front and the taillights are LED's along with a fire strip under the tailgate. Now everything works normal.
-Strange, the HD flasher should not disable regular bulbs or indicators if installed correctly.
The low cost standard flashers use the lamp load current to heat a bimetallic element in the flasher causing it to break and make the circuit. The flasher just won't operate without enuf load which causes the indicators and remaining bulbs to burn constantly. Using resistors to dummy the load is a waste and another potential failure point.
The HD and electronic flashers don't care what the load is, they have a different internal circuit that does not require a specified current draw. There are different HD flashers with specific load capacities but they are not load dependent for operation.
Patriotic Rottweiler
06-10-2018 09:54 AM
AllaboutMPG
Electrical Systems/Wiring
07-31-2014 08:21 PM
