Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-23-2007, 11:22 PM
waztmp waztmp is offline
Garage is empty, add now
waztmp is starting off with a positive reputation.
Ideal engine - 61 Econoline P/U
I am in need of finding a replacement engine (and possibly transmission) and need some advice -
Want to stick with 6 cylinders, with the price of gas; but want to have decent accceleration and ease of cruising on the freeway as well.
What should I look for in a donor vehicle / engine? Have a 3-speed on the tree tranny in it right now - along with a small rear-end set up; driveshaft is about 3 1/2 to 4 feet long, and somewhat on the skinny side.
Am more inclined to newer engines that may have electronic ignitions....
Please advise -
Waz
  #2 (permalink)
Old 06-24-2007, 07:03 AM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
144-200 will be a direct bolt in. 170-200 both have 5/16 oil pump shaft, so you can install electronic ignition in them faiarly easily. and do it with ford factory parts for ease of repair later on.
if you look back thru the old posts you will see tons of posts on econo engine replacement.
__________________
jim
underated and overworked.
  #3 (permalink)
Old 06-24-2007, 09:34 AM
Thanks much Jim. A newer 200 CI (1980 Ford) sounds like the best way to go -
Waz
  #4 (permalink)
Old 06-24-2007, 02:30 PM
Jimbare's Avatar
make sure you get the block for the high mount starter. somewhere in the early 80's, ford had 200's with the low mount starter and the wrong bellhousing pattern.
__________________
jim
  #5 (permalink)
Old 06-25-2007, 07:39 AM
Thanks again for the good advice -
Waz
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
