Thermostat housing gasket leak - Ford Truck Enthusiasts Forums
Old 06-23-2007, 11:30 PM
jlutes jlutes is offline
jlutes is starting off with a positive reputation.
I can't seem to get a good seal around the thermostat housing basically it leaks. I tried it twice and no dice. First the gasket was sealed with silicon and I got a slight leak. Second try was with gasket sealer I got a heavy leak. Each time it's in a different place. I even used the wrench with 18 Ft-lbs. Third time I would like to get it right so I need suggestions. How do you guys get a good seal? Do you use gasket sealer?
Old 06-24-2007, 07:48 AM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Make sure that both surfaces are clean, as well as the bolt threads. Lay a straight edge over the surface of the thermostat housing to make sure it isn't warped. I then put the stat in the housings recess for it and use trim cement to
hold the gasket in place. This keeps everything where it belongs while you put it in place and bolt fast. I don't use any gasket sealer on that area simply because I don't want to spend 10 minutes on clean up thex time it comes apart.
kotzy
Old 06-24-2007, 05:50 PM
doctorolds doctorolds is offline
doctorolds is starting off with a positive reputation.
As Kotzy said, "Make sure that both surfaces are clean, as well as the bolt threads. Lay a straight edge over the surface of the thermostat housing to make sure it isn't warped." If the housing is slightly warped as has scratches you can use a metal file to even out the surface, if no file is available you can place a piece of 150/220 grit sandpaper on a flat surface and slide the housing back and forth until the warpage or imperfections are mostly gone. As far as gasket sealer goes, I like to use Permatex No.2. Use a piece of cardboard or paper plate and apply a moderate coat to one side and even out the layer with your finger, flip gasket over and apply a coat to the other side in same manner. I lift the gasket off the cardboard surface and inspect the first side for any gaps in coverage, if so use the sealant still on your finger to fill any gaps in coverage. I then squeeze some sealant on my index finger and thumb and I coat the entire threads of the housing bolts. Allow sealant about 10 minutes to get tacky, insert thermostat into recess, apply gasket, put housing in place, insert bolts finger tight, and torque to specs. It works for me, good luck.
Old 06-24-2007, 06:51 PM
ENCSDEI ENCSDEI is offline
ENCSDEI is starting off with a positive reputation.
If all that doesnt work a new one can be had for under 20 bucks,I had the same problem after two tries I bought the new housing and it hasnt leaked since.
Old 06-24-2007, 07:27 PM
Quote:
Pull-A-Part has them for $4.14 if you have one near you, or another salvage yard for fairly chep, check around. I do not see it listed at the Zone.
Old 06-24-2007, 11:54 PM
notyettoday notyettoday is offline
notyettoday is starting off with a positive reputation.
napa had mine in stock for $15, it turned out my old one was cracked
Old 06-25-2007, 12:46 PM
Thanks! Permatex No.2. did the trick. I just followed the directions on the back of the tube. I cleaned the treads but I didn't use the sealer on them and I forgot to use a straight edge over the surface of the thermostat housing too. I any case I waited four hours before I tested the seal. This time I got no leak... thanks for all the good advice.
Old 06-28-2007, 09:27 PM
LarryP2 LarryP2 is offline
LarryP2 is starting off with a positive reputation.
If your housing and block surfaces are uneven, you can STILL get a leakproof seal the way I did .....
I glued the gasket on the housing, letting it dry overnight. Then instead of using bolts, I used studs with the same thread pattern. I applied gasket sealer to both the housing/gasket side and the block side. The studs helped it line up perfectly without slipping around and getting the gasket crooked like when you are trying to put bolts in. I cinched down the nuts and the thing never leaked again.
Old 06-28-2007, 11:55 PM
Wow LarryP2 thanks for the post. I don't think I could deal the block surface being uneven. If I get another leak I think I just take it to the dealer let them deal with it.
Old 07-01-2007, 08:05 PM
BulletProof300 BulletProof300 is offline
BulletProof300 is starting off with a positive reputation.
Smile Fix That Thermostat Housing Leak the Easy Way
Try using three (3) thermostat gaskets instead of just one. The extra gasket material will more than make up for corrosion or slight warping.
The only sealer I use on gaskets is "Gaskga-cinch" by Eldebrock. It is just a light rubber cement that holds your gaskets in place as you bolt things up. Your gaskets will come off easily if you have to remove them later. Gaskets are designed to seal without any help. Some sealers will actually cause leaks.
O-ring? CB3 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-03-2016 07:12 PM
I'm Losing to a Thermostat! ben73058 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 08-09-2015 11:02 AM
Rear Window Install 1966 F-250 66F250CS 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-11-2013 11:58 AM
anti-freeze in oil 2000 Mountaineer??? pilot4x41 Explorer, Sport Trac, Mountaineer & Aviator 9 02-16-2012 09:16 AM
How do you seal your gaskets? RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 4 12-07-2011 02:33 PM
Tags
03, 2000, 54, aviator, engine, f150, ford, gasket, housing, install, leak, paper, position, seal, sealant, themostat, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
