Got me a new fuel tank
Originally Posted by Excelerater
I just got an RDS im installing today......nice job
how bout some pics of the gas feed into the truck....Im puzzled there
and plan on installing it in a week or two. I plan on taking pics and doing a write-up on the install. This will be the third one that I have installed. I just use a 3/8 x 6 inch steel brake line and bend it 90* remove the filler neck and drill a hole into the steel part and braze the fuel line in. then I run 3/8 rubber fuel line to the pump I buy from Napa http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NFP&PartNumber= P4070&Description=Fuel+Pump+(Univ.+In-Line+Rotary+Vane+Type) that we have alot of success with. We used to use a cheaper pump, but they never lasted long. The cheaper ones don't like to suck air too much and that what kills them. Your gonna suck air when you get to the bottom of the tank theres no way to get around it (unless you want to leave 10 gallons or more in the tank). The Napa pump has a lifetime warranty, but we have never used it. One of my dad's drivers uses a holly pump out of one of his race cars. I will let everyone know when I have the write-up finished.
Im welding a bung into the filler neck and running a
3/8" fuel line to a fitting at the source....Grav feed
Extra Tank...
I have a 100 gallon aluminum tank on my bed. It flows out the bottom into the filler neck of the stock front tank. It also has the vent coming out of the filler neck that goes back to the top of the extra tank. I used a pump for several years with a switch and finally threw it away. I have filter and block valve between bottom of tank and and filler neck. The truck tank is alway full if the big tank has fuel in it. I also have a fuel gauge on the big tank. SO when it is empty and tank gauge on dash starts to go down, then I buy fuel. I fill the lower tank first and put cap on, then fill the big tank.. Works perfect and no pump to mess with... Also allow your diesel to burn from older to newer on fill ups....
Yes it cost more to fill up but you sure can drive a long ways between fill ups.. Guess it works out the same..... Here is picture of my setup..
http://www.ccb-design.com/Photograph...r/IMG_5165.JPG
