ford escort zx2 question - Ford Truck Enthusiasts Forums
Old 06-23-2007, 03:10 AM
burninfordrubber burninfordrubber is offline
burninfordrubber is starting off with a positive reputation.
Red face ford escort zx2 question
I have a 2004 zx2 and have recently placed a cold air intake on it. Since then every once in a while when I stop it starts to miss and then dies. but starts right back up fine it also does it really bad when aircondition is on any ideas. I thought it might be the tps but never messed with it while installing the cold air intake...
Old 06-24-2007, 10:41 AM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Don't mess with the TPS, it doesn't control idle. The idle is controlled by the IAC, which is a solenoid valve that opens and closes as instructed by the computer and routes air around the throttle plate. When the A/C is turnd on it allows more ier though to compensate for the extra load placed on the engine.
You may have knocked something (like the electrical connector) loose during your install, or it might simply be time to clean or replace it. Here's some more info on it:
http://fordfuelinjection.com/?p=39
Old 06-25-2007, 12:47 AM
ford zx2
Thanks TigerDan I will check it out and let you know how it goes. I will unplug it if it is pluged in to see if I get any hesitation.
Old 06-25-2007, 02:13 AM
dmanlyr dmanlyr is offline
dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.
Just a thought, on my son's 93 Escort GT (the 1.8L DOHC engine) the mass air flow sensor is mounted on the side of the engine compartment, and there is a rubber boot / flex tube that goes to the intake manifold. This "hose" got a split in it, right at one of the folds. This caused the enigne to surge / quit running at idle as the engine rocked back and forth on the rubber engine mounts. The surge was quite violent at times. Hard to see the crack, and it took some time to figure out what was going on.
Is your set up like this, or could this be your problem? It could act like a bad IAC I imagine ??
David
Old 06-25-2007, 08:40 AM
TigerDan's Avatar
That's not a bad thought, the engine doesn't like like it when any air is pulled into the system that didn't go through the MAF...worth checking. Might have pulled something loose during the install.
New Gauge Cluster Built kwe45919 1973 - 1979 F-100 & Larger F-Series Trucks 28 09-12-2016 04:29 PM
Do the 2001 Escort ZX2 and 2001 Escape 4 cyl. have the same engine? macarose Escape & Escape Hybrid 0 07-26-2015 12:34 PM
My Custom Dash Project (pics) kwe45919 1973 - 1979 F-100 & Larger F-Series Trucks 60 09-14-2014 10:20 PM
2001 Ford focus ZX3 [So East NH] 7283-F250 Vehicles for Sale 0 04-13-2014 07:42 PM
'Clear Flood' option? High Binder 6.0L Power Stroke Diesel 11 05-21-2011 12:17 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
bad, clean, coming, dies, escort, ford, iacv, inmediately, intake, location, manifold, starts, stop, tps, tpscom, zx2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
