2001 V10 Performance Chip - Ford Truck Enthusiasts Forums
Old 04-10-2001, 11:03 PM
chadrock chadrock is offline
chadrock is starting off with a positive reputation.
Does anyone have experience with performance chips for Superduty V10's. What is the BEST chip? Do you HAVE to use 92 octane for the chip to work or only if you want it to increase gas milage. Can you really feel the difference after the chip is installed. I lifted my truck and put larger tires on so I would like more power. I put a K&N filter in and chopped the muffler off and put a straight pipe on after the cat and can't really feel any difference. Thanks for the input.
Old 04-11-2001, 04:09 PM
Howard Howard is offline
Howard is starting off with a positive reputation.
How much larger in diameter tires did you get? If there large, you changed your gear ratio. Did you change gears? If not, that's where the power went.
Howard
Old 04-12-2001, 12:21 AM
I already have 430's for gears. Mine didn't come with the 373's so I don't really need to change the gears. I could go with 456's, but the 430's should be enough for my tires. I was told to go to 456's if you have larger than a 39in. tire (like 44's)and I don't.
Old 04-12-2001, 06:25 AM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
The Diablo and Superchips are virtually identical so far as HP/torque gains go.
Ken Payne
Ford Truck Enthusiasts Admin
Old 04-13-2001, 12:47 AM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Did you get the speedo recalabrated? That will at least get the truck running back within specs.
Old 04-13-2001, 02:20 PM
theleetbeagle's Avatar
theleetbeagle theleetbeagle is offline
theleetbeagle is starting off with a positive reputation.
jet performance chip and 6 liter tune up? Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 6 03-14-2015 10:15 PM
Power Chip or Not burlesonj Modular V10 (6.8l) 9 04-22-2014 08:22 AM
ts chip review c00nhunterjoe 1994.5 - 1997 7.3L Power Stroke Diesel 29 10-27-2013 06:54 PM
Performance Chip for Escape V6 yosemite69 Computer Chips & Tuners 2 12-05-2001 12:40 PM
Chips and Manual Transmissions Godzilla Computer Chips & Tuners 2 04-02-2000 01:08 PM
Tags
1997, 2000, 2001, 2007, chip, chips, excursion, f250, f350, ford, performance, power, programmer, towing, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
