1996 ford explorer Ignition coil pack specification - Ford Truck Enthusiasts Forums
Old 06-21-2007, 05:44 PM
vabenni vabenni is offline
vabenni is starting off with a positive reputation.
I tested the resistance on the secondary side of the coil pack. The manual tells me it needs to be between 6K-10k ohms. I am getting a reading of about 15k ohms but it is on all four secondaries. (5.0 L V8). It seems odd that the values would be thsis far off on all of them at once. Like it is somehow wearing out slowly versus a failure on one coil. Is this how coil packs go bad? slowly. Thnaks.
Old 06-22-2007, 05:35 AM
zoejazz zoejazz is offline
zoejazz is starting off with a positive reputation.
Accel Ignition Coils
In my opinion, replace them. If they are not within factory spec, they are probably effecting performance.
About a year ago I bought Accel ignition coils. My factory coils were within tolerance, but I replaced them anyway. I did notice a slight gain in performance over stock. But maybe that was a sign that my factory coils were indeed, going bad. Or maybe they are better. Anyones guess. Good luck.
Ignition Coil Resistance which one is hotter? tasboj 1967 - 1972 F-100 & Larger F-Series Trucks 0 05-30-2013 12:11 AM
Ignition Coil john fin 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 10-25-2011 04:30 PM
Engine Hesitates or Stumbles During Acceleration PersiusOne 1997 - 2003 F150 4 11-24-2008 08:19 PM
intake coil:Ohms: 1 primary, -0- secondary crazypaw Ranger & B-Series 10 04-06-2008 10:01 PM
2000 4.2 coil pack check WVF150VIANC 3.8 & 4.2L V6 21 07-29-2004 09:11 AM
Tags
1991, 2006, coil, explorer, ford, ignition, pack, specifications
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
