Competition Diesel racing, sleds, dynos, power tuning and max performance.
installing egr cooler upipe with block off plate
Old 06-30-2007, 06:42 PM
cabinetmaker00's Avatar
cabinetmaker00
cabinetmaker00 is offline
Well I had to put my truck back to stock right now ,as the weather here in so cal has been getting hot so has my truck yesterday it overheated on me
and of course my coolant was a gallon orr so low since I've been blowing it out my res so my next step is to get this http://discountpowerparts.com/catalo...oducts_id=2212
My question is can you do this without pulling the cab ,I've done the manifolds before on my previous truck but would like some input from those that have done this to there truck .
Old 07-01-2007, 06:21 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
It's a little tight, but very easily accomplished without pulling the cab. Get yourself a 10mm and a 13mm ratcheting flex wrench also. Makes the job lots easer if you have a set of those to work on a 6.0L. Pulled the turbo and cleaned it while doing this, but it's not absolutely necessary to do. Spray all the exhaust pipe bolts with penetrating oil as long beforehand as you can stand not driving your truck.
Old 07-01-2007, 04:09 PM
cabinetmaker00
cool man I only got 12,000 miles on her so all the bolts are in good shape ,just got to pull the inner fender liner and get up in there with some flex wrenches . I cant wait to see the difference without the stock piece ,should have better spool up and a lot lower coolant temps .
Matrim
02-15-2014 12:44 PM
650
01-04-2013 02:45 PM
MikeB 88
1983 - 2012 Ranger & B-Series
15
03-17-2012 07:04 AM
Tampa250
02-24-2008 12:57 PM
unrulee
Offroad & 4x4
09-20-2006 02:32 PM
Quick Reply: installing egr cooler upipe with block off plate
