Differential fluid change - Additive? - Ford Truck Enthusiasts Forums
Old 06-20-2007, 10:59 PM
bustedflush bustedflush is offline
bustedflush is starting off with a positive reputation.
1990 f250 e4od, Sterling 10.25, Dana 50.
Changed the gear oil in both differentials, Bought the expensive stuff -GL-5 Plus for limited slip differentials. Do I still have to add the friction modifier?
Old 06-20-2007, 11:40 PM
Silver Streak Silver Streak is online now
Silver Streak is gaining momentum as a positive member of FTE.
Yes, add the modifier. I'm running the high dollar synthetic fluid in both of my trucks. It's supposed to have the modifier in it already, but they chatter when I turn.
Old 06-20-2007, 11:49 PM
Thanks, I just wanted some reassurance before I dropped another $24 for the additive
Old 06-21-2007, 09:50 AM
Bruce R Leech Bruce R Leech is offline
Bruce R Leech is starting off with a positive reputation.
Quote:
wow it costs 24 bucks for that little 4 oz tube . I get it here for 2 bucks.
Old 06-21-2007, 09:14 PM
Quote:
It's 8 bucks a tube here and the manual calls for 1 in the front and 2 in the rear! (so to speak)
Old 06-21-2007, 09:27 PM
TheSharkster TheSharkster is offline
TheSharkster is starting off with a positive reputation.
When changing the rear differential lube, how should one go about cleaning out the housing and gears before re-lubing the differential?
1989 F150 4X2 355 non LS
Old 06-21-2007, 09:41 PM
If you just drain all the old fluid and put new fluid in you should be fine but if you want to be very thorough...Drain all the old fluid. Put about 1/2 to 1 qt of new fluid in and roll the truck up and down the driveway once. - don't drive it, just spin the wheels a little to get the new fluid to "rinse" the inside of the housing and gears. drain again and refill. don't forget to add the really expensive additive if necessary.
Old 06-21-2007, 09:42 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
Where'd you get it? It's fairly cheap from Ford (definately under $10 a bottle) and it's guaranteed to be the right stuff. I don't know about some of that stuff in tubes at the parts stores.
Old 06-21-2007, 09:43 PM
Was that 1 bottle or 2 in the rear??? Lmao... Thanks....
Old 06-21-2007, 09:49 PM
The 10.25" rear end calls for 8 oz. of friction modifier; the 8.8" rear end takes 4. I'm not sure how much is in the Ford bottles, I always add one to my half ton.
Old 06-21-2007, 09:53 PM
The Chilton says that my non LS only needs sae 80 or 90 without the modifier. Should I think differently? No sense spending the money if I dont need to. (Right busted??...lol)
I'm sure glad you guys have a sense of humor....
Old 06-21-2007, 10:26 PM
don't worry about it then. you only need it on certain models. But you probably want to buy the gear oil for LS diffs - GL-5 rated.
Old 06-21-2007, 10:33 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
You only need the additve if you have a L/S. Go check the door tag and find the axle code and report back. A letter then a number will mean a L/S
Old 06-21-2007, 10:51 PM
If it gets a little dirty while you are working on it witch they do when I am laying in the dirt and the wind is blowing 20 MPH. I use a small pump up garden sprayer with solvent in it and give it a good flush just before you put the cover on
Old 06-21-2007, 10:56 PM
A can of brake clean works good too. Just make sure you get it all out. The 8.8" has a little cavity at the bottom that will collect it. I don't know for sure about the 10.25".
front seal or inner axle bearings? 88_F0RD 1987 - 1996 F150 & Larger F-Series Trucks 11 08-27-2016 03:22 PM
front differential seal 1988 ford 150 88_F0RD 2011 & Newer Explorer 4 08-26-2016 06:17 PM
Rear Differential Fluid Change With Valvoline Synpower Texas Bob 1999 to 2016 Super Duty 1 06-17-2012 11:03 AM
Rear Differential Fluid Change With Valvoline Synpower Texas Bob 6.0L Power Stroke Diesel 2 06-16-2012 03:52 PM
Mobil or Ford recommended fluid for differential? Dyllan78 6.0L Power Stroke Diesel 8 01-30-2011 08:59 PM
Tags
1989, additive, change, diff, differential, end, f150, f250, fluid, limited, oil, quantity, rear, rearend, slip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
