Crank pulley runout/wobbly
Old 06-20-2007, 08:55 PM
78sharpshooter's Avatar
78sharpshooter
78sharpshooter is offline
My crank pulley wobbles noticably when the motor is running. I was wondering if the pulley can be balanced or adjusted in any way.
Old 06-21-2007, 12:29 AM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
If it is just the pulley replace it.......if it is the harmonic balancer the retaining rubber could be bad, that too should be replaced. I think someone used the crank pulley to block up the engine not knowing it weighs 1000lbs+......now it is bent.
yeahoner
07-13-2015 03:25 PM
rolltide3006
13
03-20-2011 12:59 PM
cowmilker08
02-17-2011 01:29 AM
ericfgs
09-30-2009 03:49 PM
stoney720
06-10-2009 03:33 AM
Quick Reply: Crank pulley runout/wobbly
