Wipers activate w/o being on
Old 06-20-2007, 04:45 PM
pilot10's Avatar
pilot10
pilot10 is offline
On my 06 150 a couple of weeks ago the wipers swiped once when I was parking the truck. Thought I must have touched the wiper control when reaching from steering wheel to door handle. A week later it does it again- hands are nowhere near the control.
The next week I drive to LA(400 hundred miles). Weather is in the 80 & 90s. Half way there I stop for a break. When I restart the engine the wipers come on in the intermittent mode and will not turn off. I tried playing with the switch- on/off, on/off a few times. Turned engine off then back on a couple of times. Wipers still in intermittent mode. Stop engine, remove wipers and store them in the back. Continue on my trip.
Rain not forecast until Sept/October but I still need to clean the bugs of the windshield. Took truck to dealer Tuesday for wiper issue as well as a front axle leak and an EATC issue(interior air mode turns itself off after a couple of minutes). The dealer will replace a pinion seal in the axle and a module in the EATC but could not confirm the wiper issue. The dealer indicated there are no known problems like the wiper issue. I thought there was some multifunction switch that goes out routinely causing this symptom. The service guy said the switch for the wipers is now intergrated into the fuse box-sounded like crazy talk(I hope).
Anyone hear of this wiper issue in the 06 versions?
Thanks,
Tim
One other note the radio volume seems to increase when the engine is turned off(like the commercialson TV are a little louder). I mention this in case there is some circuit both these accessories run through that may be the source of the problem
Old 06-20-2007, 11:48 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
Ford seemed to have some sort of a "Phantom Wiper" issue on some of the '99 and earlier model Rangers (mine was affected) Explorers and others that shared the same/similar set-up. You may want to locate the TSB for Ref.
I think most jus' simply made a squirt of WD-40 down Inside the wiper switch-arm to the contacts to fix. But looking on how the ones on the new 150s are a bit different maybe a bit more to it.
Old 06-21-2007, 10:30 AM
Ulf's Avatar
Ulf
Ulf is offline
There is a setting in the radio menu where you can adjust the loudness I think it is called "SPEED", it is to compensate for road noise, the faster you drive the louder the radio gets I think the settings go from 0 to 5.... (0= off and 5= loudest)
But maybee this is not your problem....
Old 06-21-2007, 10:39 AM
pilot10's Avatar
pilot10
pilot10 is offline
Thanks for the replies. I'll be a bit more patient as I do have some warranty time left(9K miles or 18 months) and I have a feeling this truck is going back a few times.
I do use the speed sensitive volume control feature - it's a 1-10 scale. I'll try turning the feature off to see if the volume still spikes when the ignition is turned off.
Thanks,
Tim
