Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-20-2007, 12:37 PM
wtroger wtroger is offline
Garage is empty, add now
wtroger is starting off with a positive reputation.
2.3L block
Can you use a 2.3 block from a 1983 and use it in a 1991 with the 8 plug head and efi.
  #2 (permalink)
Old 06-20-2007, 10:46 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
Check your post in the Ranger forum. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #3 (permalink)
Old 06-21-2007, 07:49 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
We prefer you not cross post (that is, post the same question in multiple forums) but I checked the other thread and the only reply is a suggestion to ask here. Kind of unusual not to get the replies in the Ranger/B-series forum since it sees way more activity than this one...
So anyway, there are some differences in the two blocks in question but all in all, with the right parts being used with the right block it should work. Some things that come to mind are: at some point (I don't recall the exact year of change without looking it up) the main bearing journal size was changed so I think you'd need to use the early crank with the early block. Also, later 2.3 engines had crank trigger ignition rather than a distributor. I believe an 8-plug engine was crank trigger. The earlier crank trigger ignition blocks had a plug inserted into the hole where the distributor used to be so if yours has that plug you'll need to use it on the early block. Later blocks (and I think it was about '95 so you may not be affected by this) had no hole at all so no plug was needed. If such is the case, you'd need to scrounge a plug.
I'm sure there were other differences but I can't think of them offhand. Hopefully someone else will chime in and help out here...
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #4 (permalink)
Old 06-21-2007, 12:50 PM
Thanks I knew about the main bearings and I have the complete 83 short block that was running when we pulled it out. My concern was about mounting bosses and sensors holes/mounts that the early block wouldn't have. I know the auxillary shaft drove the oil pump via the distributor and I assume the there is a oil pump/drive plug of some sort on the 1991 that would fit in the hole. Appreciate the info will see if I have to make this work.
Tags
23, 23l, 95, block, codes, correct, crank, ford, placement, ranger, short, trigger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
