Illinois Chapter Join Chapter Leader: wpnaes
starter grinding
Old 06-11-2007, 12:30 PM
mommyof2's Avatar
mommyof2
mommyof2 is offline
Unhappy starter grinding
my husbands 92 ford rangers starter went out (had a short in it,the truck worked fine before this) we replaced it (4 times ) all grind, the truck starts and runs its the starter just won't disengage,flywheel is 2 maybe 3 years old and appears fine,we just changed the cylinoid(we also tried a starter from some where else) so now we are thinking maybe a short somewhere maybe the ignition switch
Old 06-12-2007, 10:48 AM
slisty's Avatar
slisty
slisty is offline
Check at the selinoid for the short.
Old 06-12-2007, 02:06 PM
mommyof2's Avatar
mommyof2
mommyof2 is offline
we had it checked nothing wrong with that, he said maybe ignition switch
Old 06-12-2007, 10:51 PM
slisty's Avatar
slisty
slisty is offline
That could be. Hopeing someothers will chim in here to help you more.
Old 06-13-2007, 03:06 PM
Rev Den's Avatar
Rev Den
Rev Den is offline
Does the Ranger use a shim for the starter?
Rev
Old 06-13-2007, 04:40 PM
mommyof2's Avatar
mommyof2
mommyof2 is offline
it never has but we put one on still the same we also just changed the ignition switch and of course nothing we give up and taking it somewhere,thanks anyway
Old 06-13-2007, 05:16 PM
Rev Den's Avatar
Rev Den
Rev Den is offline
Perhaps check for voltage at the starter after the engine starts?
voltage at the starter would indicate that it is still trying, and rule out the starter as an issue....then all you need to do it track back the voltage.
Rev
Old 06-14-2007, 06:43 PM
mommyof2's Avatar
mommyof2
mommyof2 is offline
we figured it out, the cilinoid was wired wrong thanks for all the help
Old 06-15-2007, 02:01 PM
slisty's Avatar
slisty
slisty is offline
Glad to hear you found the trouble. We are all here help.
RumRunner78
11-26-2014 02:53 PM
birchwoodford
03-22-2012 12:16 PM
dadlovesfords
General Automotive Discussion
01-31-2009 12:57 PM
123michigan
01-02-2005 09:13 PM
jessica
07-14-2002 10:35 AM
Quick Reply: starter grinding
