Finally Caved
#62
After talking to a few local shops about gears, every one of them suggested 4.11s above anything else. I wanted to split the baby and get 4.30s seeing as 4.56s would be overkill for my application. But when I asked about 4.30s, they said it would be a better option and would get me right back to stock, but no one seems to make them. It just goes from 4.11 to 4.56 and nothing in between. They said 4.11s would give me a better highway gear vs stock. I.e. instead of 65 at 1900rpms, it would be 1816 rpms, 45mph would be about 1257 rpms instead of 1300(something). My main concern with the 4.11s is: will my truck fall out of it's power band by and lug itself with lower rpms?
Someone, somewhere, must make 4.30 limited slip gears, any ideas?
#63
#64
Originally Posted by krewat
I'd find a different shop
Sounds like they're talking about Chevies
It's 4.10's, first. Not 4.11's ... Maybe in a 12-bolt ... But not a Ford.
I've looked around for my SD, and 4.30's are all over the place - aftermarket, or OEM.
I don't get it - something's fishy...
If 4.30s everywhere, who makes them and where can I get them?
The hardest part is finding a shop in the houston area that will install something they didn't sell....
#65
Well boys, once again I've caved and finally decided to regear my truck. (the price of diesel is just now starting to hurt and I miss all the power) While reading over the past few posts, I saw that settling on 4.10s was probably my best option for all the freeway driving I do. Anyone have any objections? (i.e. I should get some 4.30s instead)
Monsta?
i eat hybrids?
Monsta?
i eat hybrids?
#66
u wont get ur moneys worth with 4.10s. Id go with 4.30s minimal. If u really want ur power back, get 4.56.
Right now, with ur 3.73's (thats what i Assume u have in ur truck) ur effective gear ratio with 315's comes out to be 3.13's
4.10's and 315's come out to be 3.44's
4.30's and 315's come out to be 3.61's
4.56's with 315's come out to be 3.83's
4.88's with 315's come out to be 4.10's
5.13's with 315's come out to be 4.31's
If it was my truck (since i love torque) it would deff be the 4.88's, but thats just my opinion
Good luck!
Good luck!
#67
Good luck!
Good luck!
I may go with the 4.56 gears then, I want my power AND my fuel economy back. I miss the fuel economy more than anything though......
#68
I don't know a thing about gearing so I can be any help there but I wanted to ask yall what you thought about axle warp. As you probably already know I put the SD leaf springs on the other night and a 2 1/2in block which gave me 4 in total. Is the 5 in SD block going to be ok to put on with the SD leaf springs or would the axle warp be the same as with the stock X springs?
I also am getting a fabtech 6in lift for the front for 665 delivered w/o the shocks so I also need help picking out some shocks.
And lastly toreador the 315's are on stock rims I see, did you have to get a spacer or do you have that much clearance with the 6in kit?
#69
Originally Posted by Toreador_Diesel
Amazing, how did you figure all this?
eric, 315's with stocks will rub unless u get spacers which are a no no. Spacers eat up front end suspension components like no other. If u need help with the shocks go to fabtechs website and find their support number and order them right up. How much lift did the SD leafs give u? If they didnt give u any lift, and if u put that 5 inch block on with a 6 inch spring on in the front, ur truck will look like u have 20 ppl in the back of ur truck. Ur trucks rear end will be 1 mayb 2 inchs at the most shorter then ur font end. U always want ur rear to be 1 inch higher then ur front end (mainly for toqing purposes so when u hitch a trailer with heavy tounge, it wont sag like crazy). That means if u lift ur front 6 inchs then ull have to lift ur rear 7. Hope this helps. If u have any more ques, PM me or just ask! Toredor, didnt u do this to cure ur sagging??
#70
#71
#74
#75
