Go Back   Ford Truck Enthusiasts Forums > Bronco > 1966 - 1977 Early Broncos
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1966 - 1977 Early Broncos SPONSORED BY:
  #1 (permalink)
Old 06-18-2007, 11:25 PM
v8xploder's Avatar
v8xploder v8xploder is offline
Garage is empty, add now
v8xploder is starting off with a positive reputation.
Leafspring bolt torque specs
Looking for the torque specs for the rear leafsprings. I just got the 5.5 11 leafs from Wild Horses. I snapped off two of the shackle bolts in the process of taking them out. Man those were tight/rusty. I need the specs for the ends of the leafsprings/eyelets. It was time to get rid of the crappy lift blocks that the P/O installed and add the 6 degree shims to make my driveshaft a little happier
__________________
Cody
92 Ed Bauer, 351w, 31x10.50 Yoko Geo's, 3.55's magnaflow catback, K&N, 2'' leveling kit, warn premiums. EV6 Injectors 13.5 avg MPG, explorer roof rack, 00' F150 console.
  #2 (permalink)
Old 06-21-2007, 11:23 PM
Boba Fett's Avatar
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
From the Ford shop manual for 67 Bronc's
Shackle Assy to hanger 60-80
Spring Assy to front hanger and shackle 110-130
Rear spring to Axl u bolt 45-60
Universal joint U bolt20-25
Universal joint to transfer case comapnion flange 40-50
Rear shock to upper 15-25 lower 40-60
  #3 (permalink)
Old 06-21-2007, 11:44 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
For the most travel, you don't want to compress the spring hangers so that they restrict movement. I have always tightened them to the point that the bolt won't turn freely.and maybe another 1/8 to 1/4 turn.
Jason
__________________
'12 Dodge 3500 crewcab 6.7 HO, Not Stock!!
'93 F350 CC 4wd 7.3 ZF and a ton of miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
Honey badger don't care...
Tags
2002, 79, bolt, bolts, bronco, center, early, f100, f150, ford, leaf, shackle, specs, spring, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
