Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-18-2007, 10:27 PM
302 F-150 is starting off with a positive reputation.
Carb swap and cam install problem
I just finished a carb swap and cam install and my engine won't start. It's a 1989 F150 302. I installed an Edelbrock performer intake and cam combo and a 600 cfm performer carb. It will turn over and pop but will not start. Any suggestions from someone who has tackled this project before?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-18-2007, 10:43 PM
baddad457 is starting off with a positive reputation.
The computer also controlled the fuel pump in the gas tank. You still trying to run that? That needs to be wired to the coil hot lead and from there thru the impact kill switch. Also needs a regulator with a return line to the tank.
  #3 (permalink)
Old 06-19-2007, 03:39 AM
HemiEater's Avatar
HemiEater is starting off with a positive reputation.
check your timing ,might be 180 off
or the wrong firing order
  #4 (permalink)
Old 06-19-2007, 06:38 AM
ken75ranger's Avatar
ken75ranger is starting off with a positive reputation.
What distributor are you using?
__________________
'75 Bronco- 5.0, c4 33" MTR's, etc.
'05 F250 SD 5.4- tow rig for the bronco.
I wheel my junk!
  #5 (permalink)
Old 06-19-2007, 08:30 AM
darrin1999 is starting off with a positive reputation.
you sure you have the timing set installed correctly (straight up)?
__________________
drive trane parts may strand you, but suspension parts can kill you.
if you cant pay cash for it, you cant afford it.
  #6 (permalink)
Old 06-19-2007, 08:49 AM
I am using a return regulator, an hei distributor, and the timing set is installed correctly
  #7 (permalink)
Old 06-19-2007, 09:17 AM
are you sure you have the distributor on constant keyed power?
__________________
  #8 (permalink)
Old 06-19-2007, 09:19 AM
I have the distributor hooked to the original white and blue coil positive wire.
  #9 (permalink)
Old 06-19-2007, 09:59 AM
What is the best way to ensure that the timing is correct
  #10 (permalink)
Old 06-19-2007, 10:51 AM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
put motor to tdc and see where the rotor is pointing.
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #11 (permalink)
Old 06-19-2007, 11:13 AM
And then whatever terminal the rotor is pointing when it is at tdc is the number one cylinder?
  #12 (permalink)
Old 06-19-2007, 11:46 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
No, #1 cylinder is pass side front. There should also be a #1 or arrow or some mark on the distributor cap signifying #1 contact. The rotor should point at that lug with #1 cylinder TDC, if it doesn't the distributor is not installed correctly.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #13 (permalink)
Old 06-19-2007, 11:53 AM
Ok, thanks a lot everyone for your help, i will go check it out.
  #14 (permalink)
Old 06-19-2007, 12:06 PM
kc5gxl is starting off with a positive reputation.
Howdy;
Are you sure that the firing order is correct? Did you use a 351 cam in your 302? They have different firing orders. If it is popping back through the intake, or through the exhaust, it sounds like the timing is not correct, or that the firing order is wrong.
Quote:
Actually, if you are looking at TDC on the harmonic balancer, the rotor can be pointing to either #1 or #6 (180 out). But like you say, if you pull a plug and bring cyl #1 up to TDC on the compression stroke, then the rotor should be pointing to #1 on the cap.
Good luck and let us know what you find.
Drive safely,
Dan Harriman 84 F150 lwb
Orange, Texas
  #15 (permalink)
Old 06-19-2007, 01:33 PM
You can use any terminal as the #1, but the rotor needs to be at that terminal and the piston at TDC of the compression stroke for this to work.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
