352 Timing Mark - Ford Truck Enthusiasts Forums
352 Timing Mark
Old 06-18-2007, 11:21 PM
Gregory Glaser Gregory Glaser is offline
Gregory Glaser is starting off with a positive reputation.
Red face 352 Timing Mark
Now that my 352 will idle in the driveway, I've been trying to check the timing but I can't locate the mark. My timing light pickup is on the front spark plug on the passenger side, my distributor vacuum advance is disconnected, I see the pointer on the timing cover, I've cleaned the ring on the harmonic balancer closest to the timing cover and still see no mark on the balancer idling or not. Could I be looking in the wrong spot on the balancer? What does the timing mark look like on a 352? Could it be my old timing light (pre-inductive pick up) is getting too dim to pick it out?
Gregory Glaser
Old 06-19-2007, 09:58 AM
Redmanbob's Avatar
Redmanbob Redmanbob is offline
Redmanbob is gaining momentum as a positive member of FTE.Redmanbob is gaining momentum as a positive member of FTE.
Probably just age has taken it's course, get some 400 grit and go around the edge till you see some tiny little marks pop up 5-0-10-20-30. While your at it verify that TDC for #1 = 0 on the balancer. Otherwise you'll be pulling hair messing with the dizzy for nada.
Just a note...this "should have" been done prior to carb tuning or is this oart of the results.
My preference:
1. Pull all the plugs "NOWS A GOOD TIME TO VERIFY TDC = 0" and read for service reasons, (ok) clean/check gap/install
2. Check rotor/cap/wires - wear, carbon track, cracks"poor gas in the cap" service as needed.
3. Check carb for leaky acc pump, general function.. fix what needs it.
4. Start engine alow to warm to normal opp temp, check idle speed - if correct pull the dizzy vac and check for vaccuum should be none. If the idle speed is correct and there is vacuum check the timing, no vacuum check it anyway. You may go back and forth a bit with timing/idle speed if timing was off.
5. Correct timing, idle speed complete cover vac hose and rev motor to check that mechanical advance is working(smoothy) connect hose and check vac advance works. "Might wanna use search and read up on this part" or ask plenty of questions this seems to have a huge argument as to how to whats too much etc... And I dunno for sure, I try to leave well enough alone.
6. Finally connect the vac guage and adjust idle mixture, you may be adjusting idle speed again as well depends... Irractic readings at this point are likely a vac leak/valve train issues... It's early surely Ive overlooked something...cant wait to hear what it was..
Old 06-19-2007, 11:58 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
those old style timing lights are hard to see anything unless your using it after the sun goes down..clean the dampner, find the timing marks and mark it with something WHITE, like chalk or paint, and find a low light area, the darker the better..if the marks are to far off, your dampner may have slipped
Old 06-19-2007, 02:13 PM
RedmanBob & Hiball3985,
Thank you for the response, I'll be on these suggestions at sundown and let you know what turns up.
All the best,
Gregory Glaser
Old 06-19-2007, 03:31 PM
PerfDistIgnition PerfDistIgnition is online now
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Quote:
This self-powered timing light has a very bright bulb:
http://www.performancedistributors.com/accessories.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old 09-01-2012, 12:41 AM
86ford302help 86ford302help is offline
86ford302help is starting off with a positive reputation.
actually you probably wont see any numbers on it .....but you are lookng in the correct spot....you will see TDC engraved in the balancer.....and the lines on mine are very faint...but TDC is engraved in it ....i had to spray some degreaser on mine to see it...hope i helps
Old 09-01-2012, 12:49 AM
im actually working on an old 352 FE right now and i cant for the life of me get it running right....i have put new timing chain assembly on it and new points new plug wires and plugs.....i found TDC and put timing chain in the correct timing....distributor is in the right spot....im not sure if i have the points set right, nor do i know how t set them correctly ....but it just wont hardly run...everytime i give it any gas whatsoever it sputters and pops....sorry to hijack ur post but i cant see to find out anything...anyone know whats making this happen.....please, any info will help
Old 09-02-2012, 09:38 PM
Redmanbob's Avatar
Quote:
Backfires through tail pipe or carb ? Some input without standing over it personally....
Vacuum Leak or stuck vacuum/mechanical advance, or poorly adjusted idle circuit causing full vac advance at idle. Put the light on it, disconnect the vac advance @ distributer and plug hose. Start confirm correct idle advance setting. Give throttle and watch for advance in timing. If it checks out and still sputters/backfires, look for a vac leak.
harmonic balancer & TDC off abyars111 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 10-04-2014 07:57 PM
5.0 Harmonic Balancer Marks Hypoid Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 06-28-2014 01:48 PM
1986 4.9L timing marks on Balancer help 1967 Tempest 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-27-2014 05:09 PM
221-260 balancer timing mark question ChrisAdams Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 03-12-2011 08:09 PM
1986 6.9 diesel Glow plugs - OR Gregory Arnold New Member Introductions 1 12-27-2008 06:52 PM
Tags
1961, 352, 360, 54, engine, f100, fe, ford, idle, mark, marks, mixture, setting, timing, timming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
