Ford F250 5.4 Liter Engine Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-18-2007, 07:24 PM
Grissomconst Grissomconst is offline
Grissomconst is starting off with a positive reputation.
Fellow Members;
Well really do not knkow where to start and I was hoping someone could mabe anwser a question/concern I have. This list below will go through what has happend thus far.
1. Bad knocking sound- (alarm in my mind and knew stuff was about to hit the fan)
2. Finally pulled the driver side valve cover and noticed several things. The cam positon sensor was GONE- and the cam gear was loose.
3. Reason for the Cam Positon Sensor being GONE- the cam gear on the driver side was somehow striped off the cam (pressed on type) and it slid forward knocking the cam sensor off. (still knocking by the way!!)
4. QUESTION- do you think this bent the valves? If not then why?
5. Anyone herd of this before?
My e-mail: grissomconst@msn.com
ANY help is appreciated (sorry for any mis spelling above)
Old 06-18-2007, 09:02 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Hi Grissonconst, welcome to FTE!
Sorry about your engine, that doesn't sound good at all. Never heard of a failure up on the front end of the engine.
What year 5.4 do you have and how many miles ?
Old 06-18-2007, 10:12 PM
Well the truck is a 2001- with 102,000 miles on it. Taken good care of but maybe I just got lucky or unlucky how ever you look at it.
My only delima is weather the valves are bent & damaged or not. If not- I would throw another cam and gear in it and see how it goes but if the valves are bent then I can't see dropping that kind of money on it when it already has 102,000 on it.
Thanks.
John
Old 06-18-2007, 10:16 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
I am willing to bet the valves are not bent at all. It is very hard to do in these engines. As long as the timing chain did not come off the cam stayed in place and would not have hit the valves.
Old 06-18-2007, 10:24 PM
carls 250 carls 250 is offline
carls 250 is starting off with a positive reputation.
if you want piece of mind do a compression test but woudn't think there is a problem. 102000 miles isn't very many in todays engines.
Old 06-18-2007, 10:35 PM
What about the valves
Do you think the valves would be ok, meaning since the cam shaft gear spun loose and the valves were not working in time with the pistons wouldn't it have bent the valves or is there enough clearance on the valves to keep them from getting damaged?
I am not really worried about the miles I am more concerned about damage to the valves themselves.
I guess I could replace the cam and gear and see what happens but that is a lot to deal with if I do find the valves are damaged and I need to do a head job on the engine.
Thanks for the reply.
Old 06-18-2007, 10:39 PM
There is a lot of clearance between the valves and the piston i would not worry about it they should be fine.
Old 06-18-2007, 10:42 PM
If that is the case being that there is plenty of clearance then what would i need to do to fix it?
P0344 and P0340 with some helpful information about camshaft position sensors NM3 2004 - 2008 F150 2 01-19-2016 06:52 AM
Cam/Crank sensor positon 08 F250 6.4 Garmoe 1999 to 2016 Super Duty 0 07-29-2015 11:25 PM
FE 360 RV cam upgrade Mudshovel_009 1967 - 1972 F-100 & Larger F-Series Trucks 35 03-10-2015 11:09 PM
2000 5.0 Explorer motor build for '64 F100 hivoltj Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 08-11-2010 01:50 PM
5.4 Engine Knock..... Loudpedal Modular V8 (4.6L, 5.4L) 29 07-09-2010 02:32 PM
Tags
54, 54liter, diesel, engine, f250, ford, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
