Diagram for C6 Transmission
Scratch that, I found the valve body diagram:
1 — Shift Valve Plate
(Part of 7A100)
2 — 2-3 Shift Valve
(Part of 7A100)
3 — Throttle Modulating Valve Spring (Part of 7A100)
4 — 2-3 Backout Valve
(Part of 7A100)
5 — Inner Intermediate Servo Accumulator Spring
(Part of 7A100)
6 — Outer Intermediate Servo Accumulator Spring
(Part of 7A100)
7 — Intermediate Servo Accumulator Valve
(Part of 7A100)
8 — Intermediate Servo Modulator Valve Spring
(Part of 7A100)
9 — Intermediate Servo Modulator Valve
(Part of 7A100)
10 — 2-1 Scheduling Valve
(Part of 7A100)
11 — 2-1 Scheduling Valve Spring (Part of 7A100)
12 — Throttle Pressure Booster Valve Spring (Part of 7A100)
13 — Throttle Pressure Boost Valve (Part of 7A100)
14 — Throttle Pressure Booster Plate (Part of 7A100)
15 7D227 Throttle Pressure Valve Secondary Spacer
16 — Downshift Valve Spring
(Part of 7A100)
17 — Gear Selector Valve Rod (Part of 7A100)
18 — Throttle Downshift Valve (Part of 7A100)
19 — Manual Valve Retaining Pin (Part of 7A100)
20 — Throttle Pressure Relief Spring (Part of 7A100)
21 — Throttle Pressure Relief Check Ball, 1/4-Inch Diameter
(Part of 7A100)
22 — Spring Seat (Part of 7A100)
23 — Boost Valve Spring
(Part of 7A100)
24 — Pressure Regulator Spring (Part of 7A100)
25 — Booster Valve
(Part of 7A100)
26 — Retaining Clip
(Part of 7A100)
27 — Main Fluid Pressure Boost Valve Sleeve (Part of 7A100)
28 — Reverse Clutch Check Ball (Part of 7A100)
29 — Main Regulator Valve
(Part of 7A100)
30 — 2-3 Shift Valve Check Ball (Part of 7A100)
31 — Converter Pressure Relief Valve (Part of 7A100)
32 — Converter Pressure Relief Spring (Part of 7A100)
33 — Upper Control Valve Body
(Part of 7A100)
34 — 2-3 Backout Valve Spring (Part of 7A100)
35 — Throttle Modulator Valve (Part of 7A100)
36 — Cutback Control Valve
(Part of 7A100)
37 — Line Pressure Coast Valve (Part of 7A100)
38 — 1-2 Shift Valve Spring
(Part of 7A100)
39 — DR-2 Shift Valve
(Part of 7A100)
40 — 1-2 Shift Valve
(Part of 7A100)
Enjoy
-Chris
(Part of 7A100)
2 — 2-3 Shift Valve
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
25 — Booster Valve
(Part of 7A100)
26 — Retaining Clip
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
(Part of 7A100)
Enjoy
-Chris
tbruz
13
07-01-2021 10:53 AM
applebaggins
09-27-2017 12:13 PM
BearFootCustom
07-18-2016 08:24 PM
85MOTORSPORTXLT
22
05-02-2016 09:44 AM
