3.0 engine stuck to trans.
Hi. I've changed a few engines before, but never had this problem. Engine is loose but won't part from torque converter. Yes, I took the 4 nuts off of the converter/flexplate & starter is out. yes, ALL the bellhousing bolts are out, any one got a idea ? Thanks, Bob
nfrost
I had the same problem separating the engine from an automatic transmission until I realized that the other end of the engine was also bolted to the transmission. at the engine mount point on the front right side of the block. Then there was also a hidden bolt holding the sheet metal onto the bell housing.
HILLBILLY BOB
04-06-2017 01:51 PM
Bob2x
07-26-2001 06:04 PM
