2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
message center too dim to see in sunlight
Old 06-17-2007, 11:17 AM
big daddy f350's Avatar
big daddy f350
big daddy f350 is offline
my dad has a 07 Expy and is complaining that the message center is too dim to see in daytime, anybody else have this problem? Thanks
Old 06-18-2007, 09:41 AM
carbonmetallic's Avatar
carbonmetallic
carbonmetallic is offline
no problems here, I think your dad needs to go get his eyes checked.
Old 06-18-2007, 01:05 PM
Jay's Avatar
Jay
Jay is offline
You're right!
Message center display is too dim and so is the radio display. HVAC display seems ok.
Old 06-18-2007, 01:13 PM
STJones's Avatar
STJones
STJones is offline
Mine seems fine. Are the lights on and the dimmer down too low?
Old 06-18-2007, 01:21 PM
Jay's Avatar
Jay
Jay is offline
No, the dimmer control is all the way up. I tried that a long time ago. Here's the question; Can anything be done about it?
Old 06-18-2007, 01:31 PM
STJones's Avatar
STJones
STJones is offline
No idea. I haven't noticed the problem with mine. I guess if there is something internally wrong it should be able to be repaired. If it is a glare issue - probably not. I guess your radio is not the nav. radio?
Old 06-18-2007, 01:36 PM
Jay's Avatar
Jay
Jay is offline
Correct - non-nav radio.
Old 08-01-2010, 10:38 AM
rqallen's Avatar
rqallen
rqallen is offline
Dim message center on 2009 Navigator
I'm having the same issue with my 2009 Navigator. Does anyone know if there is a fix and/or what can be done?
The following users liked this post:
Old 08-01-2010, 10:54 AM
berry1234's Avatar
berry1234
berry1234 is offline
Can you post a pic of how bright they are?
Old 08-01-2010, 11:38 AM
rqallen's Avatar
rqallen
rqallen is offline
Here's the pic. I hope I did it correctly. This pic was taken in direct sunlight and it shows the rest of the dash indicators to indicate the contrast between them and the Message Center. The interesting thing I noted was that when looking through the camera's viewer the Message Center display was alternating in brightness, although the varying light intensity is not detectable to the naked eye. The rest of the dash display items stayed steady.
Old 08-02-2010, 11:41 AM
berry1234's Avatar
berry1234
Looks about right to me. The Expies are not that great either in direct sunlight. Maybe get the windows tinted.
Old 12-28-2012, 05:27 AM
DeltaCaptain's Avatar
DeltaCaptain
DeltaCaptain is offline
The problem is most likely a cold solder joint on the printed circuit on the display module. I have a 2003 Expy and had this problem and I DID have a cold solder joint. The options are replace (about $500.) or check out the solder joint. A place to go might be Ford Intermittent Odometer Repair Manual Order Page Good Luck.
Old 12-28-2012, 09:00 AM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Make sure you don't have anything blocking the light sensor on the top of the dash ( hat, papers, dash cover etc....) I know on the Expy's the message center lighting dimming is controlled by that sensor. Even if you have your headlights on the message center wont dim unless the sensor determines it's too dark. You can test this by putting on your headlights during the day, the message center shouldn't dim, now cover that sensor and it should dim.
Matt
Old 03-24-2013, 10:20 PM
dalesatter's Avatar
dalesatter
dalesatter is offline
I put a piece of black felt on top of the steering column. It reduces the reflection and glare on the panel lense in bright sun.
Old 02-16-2019, 07:05 PM
CPaulsen's Avatar
CPaulsen
CPaulsen is offline
radio and message center dim on my 08 F250 also
Quick Reply: message center too dim to see in sunlight
