Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 06-17-2007, 11:17 AM
big daddy f350 big daddy f350 is offline
Garage is empty, add now
big daddy f350 is starting off with a positive reputation.
message center too dim to see in sunlight
my dad has a 07 Expy and is complaining that the message center is too dim to see in daytime, anybody else have this problem? Thanks
  #2 (permalink)
Old 06-18-2007, 09:41 AM
carbonmetallic carbonmetallic is offline
carbonmetallic is starting off with a positive reputation.
Quote:
no problems here, I think your dad needs to go get his eyes checked.
  #3 (permalink)
Old 06-18-2007, 01:05 PM
Jay Jay is offline
Jay is starting off with a positive reputation.
You're right!
Message center display is too dim and so is the radio display. HVAC display seems ok.
  #4 (permalink)
Old 06-18-2007, 01:13 PM
STJones STJones is offline
STJones is starting off with a positive reputation.
Mine seems fine. Are the lights on and the dimmer down too low?
__________________
2010 F150 SCrew 4x4 Lariat
2007 Expedition EL 4x4 Limited
2008 Mustang Bullitt
  #5 (permalink)
Old 06-18-2007, 01:21 PM
Jay Jay is offline
No, the dimmer control is all the way up. I tried that a long time ago. Here's the question; Can anything be done about it?
  #6 (permalink)
Old 06-18-2007, 01:31 PM
No idea. I haven't noticed the problem with mine. I guess if there is something internally wrong it should be able to be repaired. If it is a glare issue - probably not. I guess your radio is not the nav. radio?
__________________
  #7 (permalink)
Old 06-18-2007, 01:36 PM
Jay Jay is offline
Correct - non-nav radio.
  #8 (permalink)
Old 08-01-2010, 10:38 AM
rqallen rqallen is offline
rqallen is starting off with a positive reputation.
Dim message center on 2009 Navigator
I'm having the same issue with my 2009 Navigator. Does anyone know if there is a fix and/or what can be done?
  #9 (permalink)
Old 08-01-2010, 10:54 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Can you post a pic of how bright they are?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #10 (permalink)
Old 08-01-2010, 11:38 AM
Here's the pic. I hope I did it correctly. This pic was taken in direct sunlight and it shows the rest of the dash indicators to indicate the contrast between them and the Message Center. The interesting thing I noted was that when looking through the camera's viewer the Message Center display was alternating in brightness, although the varying light intensity is not detectable to the naked eye. The rest of the dash display items stayed steady.
Click the image to open in full size.
  #11 (permalink)
Old 08-02-2010, 11:41 AM
berry1234's Avatar
Looks about right to me. The Expies are not that great either in direct sunlight. Maybe get the windows tinted.
__________________
  #12 (permalink)
Old 12-28-2012, 05:27 AM
DeltaCaptain DeltaCaptain is offline
DeltaCaptain is starting off with a positive reputation.
The problem is most likely a cold solder joint on the printed circuit on the display module. I have a 2003 Expy and had this problem and I DID have a cold solder joint. The options are replace (about $500.) or check out the solder joint. A place to go might be Ford Intermittent Odometer Repair Manual Order Page Good Luck.
  #13 (permalink)
Old 12-28-2012, 09:00 AM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Make sure you don't have anything blocking the light sensor on the top of the dash ( hat, papers, dash cover etc....) I know on the Expy's the message center lighting dimming is controlled by that sensor. Even if you have your headlights on the message center wont dim unless the sensor determines it's too dark. You can test this by putting on your headlights during the day, the message center shouldn't dim, now cover that sensor and it should dim.
Matt
  #14 (permalink)
Old 03-24-2013, 10:20 PM
dalesatter's Avatar
dalesatter dalesatter is offline
dalesatter is starting off with a positive reputation.
I put a piece of black felt on top of the steering column. It reduces the reflection and glare on the panel lense in bright sun.
__________________
TIME IS RELATIVE TO SPEED
2008 Lincoln Navigator
2004 Lincoln Navigator
2005 Volvo S60
2000 Harley Heritage Softail
Tags
09, 2004, center, dim, dimming, display, f350, ford, intensity, light, lighting, lincoln, message, navigator, radio, stereo, sunlight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
