Differential operating temperature - Ford Truck Enthusiasts Forums
Old 06-16-2007, 10:03 PM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
Does anyone know or have a chart?
Old 06-17-2007, 08:45 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
It depends but It can get very hot, it depends on whether it's new gears and bearings or one with over, say ~5K miles or so (Broken-in). About 194F to over 370F.
I forgot where I stole this but it's likey from Amsoil or some other synthetic oil maker. I was shocked to see how hot an axle can get so I kept this:
A light duty truck towing 14,000 pounds was driven 500 miles. The test was conducted with both a new axle and a broken-in axle. Over level ground towing, oil temperature was measured at 230 degrees F in the new axle and 203 degrees F in the broken-in axle.
Oil temperature during a 6 percent grade the new axle was operating at 350 degrees F and the broken-in axle was operating at 300 degrees F.
Laboratory dynamometer test results simulating a truck hauling a trailer provided similar results, with level ground towing temperatures recorded at 266 degrees F with the new axle and 194 degrees F with the broken-in axle and towing temperatures (at a 3.5 percent grade) recorded at 370 degrees F with the new axle and 295 degrees F with the broken-in axle.
Old 06-17-2007, 09:26 AM
Yes, I found that site as well.
I have been a journeyman mechanic for 47 years and in that time have never seen a chart or any referrence.
No factory service manuals I have read make mention of it.
A fellow asked me the other day and I had that stare into head lights look.
I do know they can run quite hot and you can burn yourself.
Old 06-18-2007, 12:56 AM
tim.moman tim.moman is offline
tim.moman is starting off with a positive reputation.
For actual #s. So far I only see up to 180 on my 98 5.4 with 4.56 gears. bout 165 up to 65. 180 above that. rain brings it down to 140. Will be interesting to see if/when I do my first hot weather heavy trailer pull. Sure don't want to see that 300 deg mark.
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
axle, differential, end, ford, hot, inch, inside, operating, opperating, rear, temp, temperature, temperatures, tempurature, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
