Actually I'm planning to buy a 2009 f-250 CC diesel for heavy pulling. Now that rumors of the 2009 f 150 with the opt. 6.2, I will buy it also. I don't need the f 150 for heavy pulling. I will rather for performance truck.
__________________
1973 F-100 360gas110000m
1985 Mercury Marquis 3.8gas 186000m.(Junked)
1994 FordAspire1.3gasStillalive 234000
1999 F 250 Work Truck159000
2002 Excursion 69000
2005 FordFocus24000
1997 PlymothMinivan167000 M
2008 F250 FX4x4 Diesel Supercab
I want mileage. GM got us really good mileage with a really crappy diesel until 97 or so. I'm talking mid 20's. There's no reason they can't build us such a truck now. They just won't. I don't care about speed. If it will keep up with my curren't v6/5spd I'd be happy. If I want to tow something bigger than a car, I'll get a bigger truck. I use the bed of my half ton every single day, but I don't ever look around feeling like I need a 3/4 ton, or for that matter more power.
I know some guys here don't think it's possible, but I want to see that elusive 30 mpg (at least the 2wd) full size pickup. I would trade my new 07 in on it tomorrow if it got better than 25 mpg.
I've driven lots of F-150's with the triton 5.4L and i was kind of surprised as to how week it is compared to the chevy vortec, to me they should really build the V8 to give it some more power before they even think about making the diesel because right now the twin turbo diesel isnt doing so great. ALOT of recalls on it so far, putting a diesel in the F-150 right now wouldnt be such a great idea!
For an every day driver Diesel will cost more, fuel for the disel will cost more. Yet fuel mileage will be better.So You need to sit down and understand the mileage between both and the mileage you drive and do a cost analysis taking into account the above costs and see how long it would take to break even comparing both. If the brake even is beyond your normal ownership then I would say diesel would not be advanageous.
Now if you need the power of a diesel for towing etc.. then the cost is not an issue.
One other thing based on my last bit of info the F150 is slated for a 4.4 diesel. So the power and mileage may be a bit mute.
The new 6 speed tranmission is due out for 2008/9 this should wake the truck up quit a bit.
For my uses a 4.6 is plenty, I don't tow much of anything. The only hauling I ever do is a few sheets of ply and some 2x4s for projects. I might get the odd item that's a little heavy, or softener salt, or mulch. If I need gravel or heavy machinery I have it delivered. It's more cost effective for me.
__________________
1992 E150, 351, 1 ton E4OD (RIP)
Courtesy of my WIFE: "Why do they call it 'scruff' when it's more like mini-daggers?"
A lot of things have changed in the world of diesel, or should I say clean diesel now, just over the past 5 years changes have been major to say the least. The 6.0 was plagued with problems largely do to emmision controls that are strapped all over it.
The 6.4 is even more complicated than the 6.0. The reason the 7.3 was such a legend in dependability was that it was simple by comparison to the 6.0 and real simple when compared to the 6.4. I am sure the 6.0 would have been just as reliable as the 7.3 had it not had to meet the 2003 emmision regulations the fed passed, then again the 7.3 would have never been replaced if not for the new 2003 emmisions standards. The 6.0 was a bandaid in way to bridge the gap to 6.4L and the 2007 standards.
The new 6.4 was brought about for the same reasons, to meet the even more extream 2007 emmisions that has a yet a another part kicking in come 2010. I hope that logevity still proves to be good after all this new high tech high heat technolegy has been in effect and on the road for a few years. I have had several 7.3s and now have several 6.0s in my company fleet and at home in the garage.
The guys I have talked with that have the new 6.4 say its quiet and they like that feature, but they are not very fuel efficent. Much the same as my milage went down when I went from the 7.3 to the 6.0, it would seem that the same is happening with the 6.4.
Right now the Dodge seems to be haning in there with its mpg numbers but thats largely do to the fact there new 2010 engine is backed with a 6 speed auto and not the old 4 speed that backed the 5.9. I have herd Ford is in the process of adding a 6th gear to there automatic diesel transmissions do out next year. That should get the MPG back to the level of the 6.0s anyway. I am a firm bealever had we had a 6 speed auto behind those old 7.3s we would have been well into the 20mpg range.
I am excited about 1/2 ton diesel's don't get me wrong, am just not going to jump out say that all the old rules and benifits of diesel are still with us on these new engines. Think about this. The reason the new SD nose was extended and the hood raised a bit was to accomidate the 7 radiators that the new high tech 6.4 is using to try and keep everything running cool. All that heat and were talking a diesel. One of the big reasons diesel engines use to last longer than gas engines, was because they ran at cooler temps than the gas engines. I am not sure thats the case at all now.
I don't know about where you are from but over the past 3 months Diesel here has been a lot sheaper than regular unleaded, about 30 days ago I was paying 70 cents per gallon less for diesel than for gas. Now its been runing about 20-30 cents a gallon cheaper than gas for the past 30 days. Yesterday gas was 3.09 here and Diesel was 2.79
