Axle nut socket
I would strongly recommend to just go get the socket...it is a very very inexpensive investment and will prevent you from dinging up the other threads for the hub assembly...it only costs about....$20-$25 at your local autoparts store. Like my uncle alway told me..." if yer gonna go to work...don't do a sloppy job."....so yeah just purchase the right socket.
Punching the nut loose is what you do if you're either on the road without the right tools, in a jam, or if you need the money for baby formula and can't afford to buy the right tools.
If you aint got kids on baby formula, and you aint on the road, or just aint plain deperate, then bite the bullit and buy the tool.
And yes, I am speaking from experience. I have used a hammer and screwdriver. But if I could have afforded the socket, I certainly would have made that my priority. Much easier in the long run, and less chance of screwing something else up. I now have in my tool box a spindle socket.
Good Luck, Tim
Good Luck, Tim
Some places like Auto Zone may loan you the proper tool for a refundable deposit. If you depend on the truck - it's worth doing it right. Replacing parts ? I'd recommend replacing BOTH sides. - The right side going out means the left ain't far behind. A bit more trouble now but a lot less trouble later.
Originally Posted by YoungMT Hick
ya buy the socket just got done taking mine out on a 74 there is two nuts outer then an indexing ring that has a bunch of little holes in it then another nut with a little tab that goes in the holes. get it it helps try to find a friend that has one
Originally Posted by flcracker9
The Dana 60 is a little different than the Dana 44. The Dana 60 has 2 hex shaped nuts (much larger than the 44 nuts), and a large washer with tabs (the tabs are bent downward to lock the outer nut) that's sandwiched between them. you will need to use a punch to bend the tabs back and away from the nut, then use the proper socket to remove the nuts.
It's a little tough to bend the tabs back down when you put it back together, I use a long prybar that has a head like a screwdriver, and slide it in on an angle, and pry on one corner of the tab. Once I get a corner of the tab bent down, I come straight in with the prybar and pry the whole tab down, using the outer hub as a fulcrum
May be a 'too late' post . . . I'd recommend tightening the nuts down with a torque wrench. Just what I do - I've seen a few come loose from "hurry", and a couple that were almost wrecked later when they were tightened too much. Common sence should prevail if you like your truck - like most of us do.
mic91F150
01-01-2016 09:40 PM
davlun
08-11-2014 03:56 PM
