2003 Expedition not starting
When the ignition is turned over, it does crank... just sounds like it is starved for fuel.
Listened for the fuel pump whine when turning the key and nothing... checked the fuse (#34; 20 amp fuse) and it is okay. Does this mean the fuel pump died??? Or could there be a sensor that is no good, cutting power to the fuel pump??
I noticed the fuel pumps are pretty high $$$.... just wondering if anyone else has had a problem that is similar???
If the truck turns over but doesn't start it might be the Idle air control valve (IAC or ICV). This happened to my truck a couple of months ago. Next time you try and start the truck pump the gas pedal like an old carburated engine. If it starts that would be my best guess and cheapest guess. ICV around $50.
08F150White
2004 - 2008 F150
07-20-2016 06:59 PM
Powerstroke-7.3
13
12-29-2009 02:45 PM
wjschaller
03-21-2009 03:43 PM
