Y Block Water Pump - Ford Truck Enthusiasts Forums
Y Block Water Pump
Old 06-14-2007, 08:22 PM
stockcar nut's Avatar
stockcar nut stockcar nut is offline
stockcar nut is starting off with a positive reputation.
Y Block Water Pump
OK, guy's, I'm looking for the water pump for a high mount fan that fits the later timing cover. It is the bigger pump. i already have a small pump but I used the 272/292 timing cover for the bigger pump. I need the pump with the flange for another purpose. I don't need part numbers, I already have everybody's part numbers, I need a rebuildable core. Please check your parts stash for a core I can have rebuilt. Thanks a bunch, Tom
Old 06-14-2007, 08:56 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Are new ones no longer available?
Old 06-15-2007, 03:00 PM
Buz, I can't locate one. Just about everybody lists the pump I'm looking but no one can get one. I don't absolutly have to have one but it would eliminate a bunch of headaches on the truck to have one. Tom
Old 06-15-2007, 03:09 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Howdy,
I have a new one still in the box. It's the one that fits a 292 (mine is a 292 from a 61 F-100)
I won't be using it if I decide to go with electric fans.
Send me a PM.
Regards,
Rick
Old 06-16-2007, 11:54 AM
Rick, I sent you a PM. Tom
Old 06-16-2007, 12:26 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1956 (272) 1957/64 (292)
What are you working on??
1956/64 F Series Trucks
Only one waterpump was used for ALL 1956-64 = B6C-8501-B.
Only one timing cover was used for ALL 1956-64 = C2TZ-6019-A
These are used on Ford Y blocks, NOT Lincoln Y blocks.
1955/63 272/292 Y block passenger cars use a different waterpump and timing cover (exc 55-57 T-B), than the trucks do.
Timing cover = C2AZ-6019-B
Waterpump = B6A-8501-B (inc. T-B).
Old 06-16-2007, 02:24 PM
HT32BSX115's Avatar
For everyone that's wondering what a "High Mount" pump is,
it looks like this:
It would be the pump for a 1956 272 panel type truck that had the radiator a little higher than normal. The fan mounts on the flange on top. It moves the centerline of the fan up 4 or 5 inches .
My 55 F-600 used one with the 239 also.....albeit a slightly smaller one.
The one above is the one I have now for the 292.
Cheers,
Rick
Old 06-16-2007, 03:01 PM
The 1948/56 Ford Truck Parts Catalog lists one waterpump (B6C-8501-B) for 272 Y block 1956 F100/350 & F500/600 WITHOUT the 272 H/D engine.
The 272 H/D engine was NOT used in 1956 F100/350's.
There is NO reference that states anything about a radiator position on F100/350's.
>>> The 1955 239/256 Y block waterpump is the same for all models, and is also used on the >> 1956 272 Y block F500/600's with the H/D engine: B6T-8501-B. This is the HIGH MOUNT pump you are refering to. <<<
The 1954 239/256 Y block waterpump is different: EAT-8501-B
Old 06-16-2007, 04:06 PM
HT32BSX115's Avatar
Bill,
I think the pump I have was supposed be for the 56 P500? It fits the 292. The other high mount pump that came off the 239 is smaller and will not fit the 292 timing cover.
If I used a "regular" pump the fan would not be centered on the radiator.
I suppose I could use a different radiator or shroud etc.
I don't know what my 239 came out of. I know it was a very highly modified engine. It had a 239 block number and what appeared to be 272/292 heads if that's possible. It had a cam that worked with a 14 tooth dist. It had the smaller timing cover and the smaller high mount pump.
I now have a completely rebuilt 292 from a 1960 F-100 ready to go in the F-600. I need to fabricate a front cross piece so I can install the front 2 point engine mounts.
The position of the engine & radiator is such that I need to mount the fan using the high mount pump to center the fan on the radiator.
Otherwise, I'll either have to use electric fans or lower the radiator & shroud.
This truck originally came with a 223 L6. Someone back when I was in grade school swapped it out for the severely modified 239.
Cheers,
Rick
Old 06-18-2007, 12:22 PM
Rick, I think I have finally located a water pump like the one you have. It was shear luck and almost right under my nose. Thanks for the help.Tom
Old 06-18-2007, 12:48 PM
Bill, I respect your vast knoledge of obsolete Ford part numbers. I,too, have been a counter man and also a parts manager. I was also a line mechanic and am a top notch salvage yard scrounger. First, all parts books will lie to you once in a while. Second, nothing at Ford Motor Company was ever carved in stone. Third, if you had read my first post you would have known that I said nothing about year model or truck size, only a discription of the water pump i need which I know for a fact does exist. I did not need your obsolete part numbers, I have Ford Dearborn parts books from 1932 through 1956. No disrespect intended, just correcting your misinturpitation. Thanks,Tom
Old 06-19-2007, 12:43 PM
Rick, I just got back dfrom the parts house where they refer to me as that nut building the Y block. I now have the correct pump, just like yours. Thanks again for the help, Tom
Old 06-19-2007, 02:48 PM
HT32BSX115's Avatar
Hey,
Glad you found one. They seem to be somewhat scarce.
Keep us posted and take lots of pictures!
Old 05-03-2009, 08:34 PM
56Fred 56Fred is offline
56Fred is starting off with a positive reputation.
Hi Guys,
Anyone have another one of these high mount fan Y block water pumps for a 272? I have been trying to locate one for a buddy of mine with a '56 f100 he is rebuilding. If you do, please let me know.
Thanks my friends.
Old 05-03-2009, 09:12 PM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
geez and i want the car stuff for mine , rick i'll have that balancer / pulley boxed up and get it weighed etc. purty quick here hopefully .
Part numbers for 300 water pump pulley kydavison Ford Inline Six, 200, 250, 4.9L / 300 8 09-27-2016 01:56 AM
Bolt problems Nathan Cox 1987 - 1996 F150 & Larger F-Series Trucks 7 09-15-2015 02:08 AM
Help with '95 F150 Water Pump, Timing Cover MavSprint 1987 - 1996 F150 & Larger F-Series Trucks 2 11-20-2012 08:02 AM
Pulley Problem 1966F100240CID 1961 - 1966 F-100 & Larger F-Series Trucks 5 10-09-2009 09:36 PM
water pump nightmare bronco93@Miami 1978 - 1996 Big Bronco 20 08-29-2003 04:22 PM
Tags
1954, 1955, 1956, 1960, 256, 292, b6c8501, b6t8501, block, eat8501b, ford, install, pump, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
