Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-14-2007, 05:44 PM
rprhyno rprhyno is offline
Garage is empty, add now
rprhyno is starting off with a positive reputation.
shell gas cleaner? - article link
For those of us that have pondered the Shell Gas ad campaign claiming their fuel burns cleaner, here's a link to a USAToday.com article: http://www.usatoday.com/money/indust...gas-usat_N.htm
  #2 (permalink)
Old 06-15-2007, 09:39 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Interesting. Valero, currently the #1 gasoline refiner in the USA was not mentioned at all. Anyway, it looks like the Tesoro gas I have been buying lately has only the bare minimum of additives. I can get Mobil or ARCO (BP) for only two cents more a gallon. The "top tier" brands are more expensive, a lot more than the one cent it costs for the extra detergents.
Jim
  #3 (permalink)
Old 06-15-2007, 12:06 PM
christcorp's Avatar
christcorp christcorp is offline
christcorp is gaining momentum as a positive member of FTE.
Personally, I like the idea that some providers like Exxon/Mobil and Ford don't join this "Top Tier" consortium. Exxon shouldn't have the auto makers dictating what additives go into the gasoline. There will be too many auto manufacturers wanting different additives. Supposedly to work the most effectively in their automobile. You don't tell the phone company to change their wiring or system to work on a particular fax machine or standard. You make the fax, modem, pc, etc... manufacturers build their equipment to be compatible with medium on which it rides on. Same here; The EPA dictates a certain minimum standard for fuel to assist in improving emissions, less varnish, less total gunk in the engine. Now that the fuel is at the standard, it is up to the auto manufacturer to build a vehicle that runs efficiently on that fuel. It's a lot more difficult to design a gasoline to work on 50 make/models of vehicles, than it is to have the auto manufacturers build their vehicles to work with 1 gas standard. If the gasonline providers want to go ABOVE the standard, that's their choice.
I think that is why I like Exxon/Mobil. From an oil company comparison, I believe that they do have a set of standards that are higher than the EPA. I also LOVE the fact that they don't include ethanol in their gas; at least in my state. Even the link above commented by a person who use to work for the EPA who said he doesn't care about "Brand" gasoline, but he WON'T get gasoline that has ethanol in it. Kudo's Exxon/Mobile. Also, it seems that Ford is building their vehicles to work on the fuel source available, instead of trying to force the fuel providers to change the additives in the fuel to work on their vehicle. Kudo's Ford.
Where I live, Exxon/Mobile fuel costs about the same as the Mini-Mart, Walmart, or any other station. Most have E10 oxygenated ethanol. I will stick with Exxon/Mobile without question. Later... Mike....
__________________
The Ford Family:
2000 Ford Focus - 143,000 miles
1994 Ford Explorer (4.0l V6) - 114.000 miles
1994 Ford F250 (460 V8) - 65,100 miles
1966 Ford Mustang (289 V8) - 141,200 miles
"Born Wild; Raised Proud"
  #4 (permalink)
Old 06-18-2007, 09:20 AM
E10 is mandatory here, so brand makes no difference when it comes to that.
Jim
  #5 (permalink)
Old 06-18-2007, 12:24 PM
70blue's Avatar
70blue 70blue is offline
70blue has much to be proud of70blue has much to be proud of70blue has much to be proud of70blue has much to be proud of70blue has much to be proud of70blue has much to be proud of70blue has much to be proud of70blue has much to be proud of70blue has much to be proud of70blue has much to be proud of
Shell gas in my area cleans your fuel system real well. Shell has started using E10 in my area. It cleaned my fuel system too well. That little bit of ethanol cleaned enough rust off my filler tube to expose pinholes. Now if I get to 1/4 tank my truck starts starving for fuel. I will not touch shell until I fix my fuel tank. After that I will go to using it again.
  #6 (permalink)
Old 06-22-2007, 04:34 AM
jasongt06 jasongt06 is offline
jasongt06 is starting off with a positive reputation.
I have found that there seems to be no difference in using any of the name brand gasolines. I have found that my vehicles get less MPG when using some of the no name gas.
Tags
article, cleaner, cleaners, comparison, gas, gasoline, mobile, shell, tier, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
