How often should I change my fuel filter? - Ford Truck Enthusiasts Forums
Old 06-14-2007, 04:03 PM
Hurricane Hurricane is offline
Hurricane is starting off with a positive reputation.
I have an 02 F250 PSD 7.3L 4x4 crew cab. I bought it used in Dec. 2006. It didn't come with an owner's manual so I wanted to know how often you are supposed to change the fuel filter. Truck has 100,000 miles on it now.
Thanks, Chris
Old 06-14-2007, 04:07 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
Most people do it about every 10,000 miles I believe - maybe every other oil change? How's this:
1. Every 10,000 miles or every other oil change
2. More frequently if you get dirty fuel
3. More often if you just started running biodiesel
Old 06-14-2007, 04:52 PM
mustang_gt_350 mustang_gt_350 is offline
mustang_gt_350 is starting off with a positive reputation.
Saying this not knowing if you have changed it before.. If you do change it make sure what kind of filter you have in it already. As in the some filters come with the bowl lid and filter as 1 piece, so if whoever had the truck before you changed this out to one of them and you don't have the factory cover and you buy just the element its not going to do you any good. The truck i got just last month had a purolator filter in it. So i got the same filter again since i do not have the factory fuel bowl lid.
On the filter change issue. I have heard anywhere from every other oil change to whenever it feels sluggish and needs it. I'll probably go with every other oil change or 1 time a year since I usually won't put more than 10k miles a yr on my truck.
Old 06-14-2007, 05:00 PM
What's the deal with biodiesel? Can I just run this in my truck or do you have to have the truck set up for it? Is there any advantages/disadvantages to it?
Great thanks guys, I think I'll change it now since I've got to change my oil anyway and then do every other oil change.
Old 06-14-2007, 05:12 PM
Bio tends to clean out the gunk that builds up in fuel tanks, etc. and when that gunk gets to your filter it just clogs it up faster.
Old 06-14-2007, 05:20 PM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Like Papa said, it has a detergent effect and will clear the fuel lines of gunk the first couple of times you use it, so keep a couple of fuel filters on hand. Especially with over 100K on the truck. My neighbor ran some this spring and his 350 had only about 28K and his truck wouldn't stay running after that first tank. His filter was all clogged.
Old 06-14-2007, 05:28 PM
So I guess it would be good to run a tank of it every once in a while?
Old 06-14-2007, 08:20 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I change my fuel filter at 15,000 miles, but I tend to put a few more miles on the truck than most. As for biodiesel, it depends on what percentage you are running and how dirty your fuel system is. I started running B20 at 155,000 miles and never had an issue with clogged filters, or the filter getting dirty quicker than normal. I checked it once a week to be sure. Look inside your fuel filter bowl and if it looks clean you should be ok with a B20 blend. The closer you get to B100 the more detergent effect it has.
oil ken1960 6.7L Power Stroke Diesel 27 12-06-2013 02:12 PM
How many miles should I change oil and fuel filter Bvill01 1999 - 2003 7.3L Power Stroke Diesel 21 10-09-2012 07:41 AM
Fuel Filter Change Interval '94IDITurbo7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 03-08-2012 11:14 PM
Fuel Filter Change? How Often? bebeard 1999 to 2016 Super Duty 7 12-15-2011 12:34 PM
Newbie with some basic maintenance ?'s 952X4 6.4L Power Stroke Diesel 4 03-26-2010 05:26 PM
Tags
2003, 2006, 60, 73, change, diesel, f150, f250, f350, filter, ford, fuel, fule, gas, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
