problems with oil pressure - Ford Truck Enthusiasts Forums
Old 06-14-2007, 12:45 AM
effie_man's Avatar
effie_man effie_man is offline
effie_man is gaining momentum as a positive member of FTE.
well i took her for a rip on the highway and the guage slowly ran down from normal, which is around a quarter to a half on the guage, to just above the zero mark. I checked the oil, full. Checked the wires and i got good power and everything to the sending unit. Im going to take it off and clean it and try it again. If anyone has any ideas they would be greatly appreciated.
Old 06-14-2007, 11:33 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Worn bearings. When the oil is cold you have more pressure. As the oil warms up it get thinner and you have less pressure.
Think of your oiling system as a controlled leak. As bearings wear, tolerances increase and the leakage increases resulting in less pressure.
You might try a mechanical oil pressure gauge - the stock version just gives you a rough idea of whats happening.
Fortunately, if a flathead has SOME oil pressure it'll probably do just fine if you take it easy.
You could also try additives - Lucas or STP - but there are always trade offs. Only real cure is new bearings.
Old 06-14-2007, 11:47 AM
effie_man's Avatar
ya i just contacted the guy i bought it from and he said that it would do that when it was hot outside. He just said to check the oil regularly
Guage Problems again lbrauer 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 10-24-2010 05:01 AM
Fluctuating Oil Pressure Guage nnero 1987 - 1996 F150 & Larger F-Series Trucks 2 10-27-2009 09:04 PM
Price of Guages preppypyro 1999 - 2003 7.3L Power Stroke Diesel 22 02-07-2008 07:38 AM
1991 Ranger 4.0 Gauges ?????? Garyinreno Ranger & B-Series 5 02-07-2006 10:00 PM
help drumman1225 1987 - 1996 F150 & Larger F-Series Trucks 1 08-02-2005 06:50 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
