does anyone have problems with water building up in the rear tail lights? i have had it in a few times with no fix. now ford have covered the old vent holes and drilled new ones...pretty lame
[updated:LAST EDITED ON 06-May-02 AT 01:03 PM (EST)]I had water in one of my Stock Foglights on my Xped. I think the lights are just sealed poorly (more cost effective i guess). I removed the foglight, drained the water, then put a bead of Hot Glue around the seal. I did this a few months ago, and haven't seen any condensation as of yet. Im sure there are better things you can use, but the hot glue was readily accessible at the time. Hope this helps.
