Victor EFI Conversion
Originally Posted by 408bronco
Don't know do you have any pics??
http://www.supermotors.net/vehicles/registry/4103/24065
Complete engine build with pics, prices, and part numbers here.
http://www.fullsizebronco.com/forum/...ad.php?t=58954
I have seen the TFS-R used on a F250 with a little modification.
The set up you have is that the Truck EFI?
I will be having a chip burned soon to run 30lb/hr injectors and a 90mm L-MAF.
Thanks Gacknar, It looks like there is plenty of room on top. I am also going to use the 90mm LMAF.
Did you use a different throttle linkage or did the original one hook up OK? What about the coils that sit on the drivers side manifold bt the head?
Did you use a different throttle linkage or did the original one hook up OK? ?
http://www.supermotors.net/vehicles/registry/4103/51928
And modified it to run the TV for the AOD
http://fullsizebronco.com/forum/showthread.php?t=76361
I dont have a smog pump so I dont need TAB and TAD.
I do have good 3-way magnaflow converters that dont need AIR to make up for no smog pump. I pass metro Atlanta emissions tests with flying colors with this setup.
Originally Posted by Gacknar
Short runner intakes such as the TFS-R or Edelbrock RPM are usually poor choices for heavy trucks. The power band is just too high in the RPM range for most (not all) truck aplications.
Thanks for the info on the throttle bracket. I am also talking with a guy on the lightning forum that has a Gen 1 and his brother converted an F-150 to a lightning set-up.
I thought you probably used the lightning bracket. Does your EGR work or is that just for show?
That's great the 96 works on a different principal, so I will program it out of the ECM.
BTW, where did you get the intake duct? Is that lightning also?
http://www.jagsthatrun.com/Pages/Par...n_Ducting.html
deced
04-19-2005 11:58 PM
Victor23
General Automotive Discussion
10-07-2004 07:23 PM
polcat
04-16-2004 07:30 AM
