Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2010 4.4L Ford Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2010 4.4L Ford Diesel Discuss the upcoming 4.4L Ford diesel engine
Is F-150 Still King?
LinkBack Thread Tools
  #61 (permalink)
Old 05-16-2008, 06:33 PM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by luthrobediesel View Post
what all kind of problems did the 6.0 have i seem to remember flames coming out of tail pipes.
You mean the 6.4 don't you?
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #62 (permalink)
Old 05-20-2008, 03:34 AM
hairyboxnoogle's Avatar
hairyboxnoogle is starting off with a positive reputation.
I dream of the day when i could buy a Ford truck with a Cat engine in it.... even a Detriot wouldnt be bad. IMO one problem with new engines is just as stated above. "let the engine builders build the engines, and the truck builders build the trucks" not buy an engine and mess with it. Dodge/Cummins is having an issue with this atm. And very obviously, so is Ford/ International
  #63 (permalink)
Old 05-20-2008, 08:06 PM
deereman4020's Avatar
deereman4020 is starting off with a positive reputation.
Question John Deere KICKS A$$
Quote:
Originally Posted by Passin Thru View Post
Ya, I ran a CAT 3406 E for 4 years and the only problem we had was an injector stuck for some reason and they fixed it free. Id love to bolt a 4 cyl CAT up in my pickup. Bet it would run, those John Deerre engines do also.
Nothing runs like a Deere, or smells like a John.
are you dissing John Deere diesel engines? They set the standard for farm equipment engines. i take bad words on John Deere PERSONALY
  #64 (permalink)
Old 05-20-2008, 08:09 PM
thorseshoeing's Avatar
Sexxxy Beast
thorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant future
Quote:
John Deere is over priced and over rated...You can get much better a Deere...
Tim
__________________
Tims' Minions-Fearless Leader (and stud)
Quote:
Originally Posted by KitsKid
So there, I hope that answers your damn stupid question!
Quote:
Originally Posted by fastmover
Gee... I didn't think it was a stupid question.
  #65 (permalink)
Old 05-20-2008, 08:51 PM
smokewagun is starting off with a positive reputation.
Just asking, but doesn't Yanmar make the diesel engines in many John Deere tractors?
__________________
2007 F-250 Lariat Crew Cab 4X4 6.0 Stroke SWB Dark Toeador/Silver
  #66 (permalink)
Old 05-25-2008, 02:36 AM
Fosters is starting off with a positive reputation.
Quote:
Originally Posted by KrenzyRyan View Post
Honeywell Is moving alot of their hardware (outsourcing) to Chihuahua - and so far none of it is coming back good...
A lot of companies, in a lot of industries, turn to outsourcing stuff, and it always has the same results. It's puzzling, really, you can read about just about every company that has outsourced stuff and the problems they faced... yet every company out there thinks they'll be the one company who's gonna get the same quality and save costs...
oh well... at least back in the day, the mexican blocks for the 302 were actually stronger than the blocks made here. so lets hope they get these motors right too? :-)
__________________
2000 Excursion Limited 4x4 V10 - soon to not be stock anymore.
2004 F150 XLT screw 4x4 5.4 - 2.5 leveling kit, 34.5" BFGs - Gone
2004 mach1 mustang, holding the garage floor in place.
  #67 (permalink)
Old 05-25-2008, 07:07 AM
tex25025's Avatar
Quote:
Yes in the compact utility tractors Yanmar does make the engines in those. Nice little engines for a small package, however, you get into the big boy tractors those engines are made by Deere.
__________________
Fluidampner
Headstuds
FASS 150/180
  #68 (permalink)
Old 05-25-2008, 07:13 AM
tex25025's Avatar
Quote:
Tim
Not really, atleast not in the other ones that I have had experiance with compared to my friends. I have one tractor that was built in 86, the hourmeter has rolled over just about 3 times now and there has not been one rebuild on the engine(the techs are just waiting though, they thought they would have had to do it this past fall, but no), my friend had a Kubota(which has the 2nd biggest presence in this area) and has had multiple problems with and not to mention on their tractors(not just the mowers, but the tractors as well) you have rubber ignitions for the keys, meaning that rubber over time will wear away and you can start that tractor with your house key eventually, not a good design. Now on their mowers, Deere does that(I think it's just an industry standard) but for their tractors they do not.
__________________
Fluidampner
Headstuds
FASS 150/180
  #69 (permalink)
Old 05-25-2008, 08:06 AM
Sexxxy Beast
Quote:
I wouldn't take a Kubota if it was given to me.
I'm not saying that Deeres' aren't good...They just cost too much up front, and parts are a lot higher than other makes.
You say your hour meter has rolled over 3 times now...That's what, over 30,000 hours...I can't say that I've seen one with that many hours on it.
Tim
__________________
  #70 (permalink)
Old 05-25-2008, 08:11 AM
tex25025's Avatar
Tim
Almost 3 times. The bulk of that was because it was used on a big farm and they used that poor little thing for everything. In actuality it was a little small for what they needed(which I'm sure is how I got it), but the local JD dealership has all the paper work on it, because I couldn't believe that either. Everything still tests good though.
__________________
Fluidampner
Headstuds
FASS 150/180
  #71 (permalink)
Old 05-26-2008, 09:13 AM
poppie is starting off with a positive reputation.
-------------- An fyi tex, in compact tractor's yanmar make's the whole tractor,not just the engine!!!!
__________________
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, 2007 expy Eddie Bauer,redfire&tan,power fold rear seat's.
My truck and 5er.
  #72 (permalink)
Old 05-26-2008, 09:37 AM
tex25025's Avatar
Quote:
Starting in the 90s I believe, earlier ones like the 650 it was just the engine.
__________________
Fluidampner
Headstuds
FASS 150/180
  #73 (permalink)
Old 05-26-2008, 09:51 PM
TheNomad is starting off with a positive reputation.
I haven't read the whole thread so i'm sorry if any one has said this all ready.
But who cares about Diesel trucks now any ways..
Diesel is all ready 5 bucks a gal here, how much is it going to be around the time they want this truck to come out 10 12 higher? Will any one even buy them?
__________________
1979 F-150 Ranger 302.
1979 F-150 Ranger 460 in the works
So many dogs and yet so few subsonic 22s
NRA
TRSA
  #74 (permalink)
Old 05-27-2008, 12:21 AM
monsterbaby's Avatar
monsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant future
You know who cares about diesels? People that understand how much more fuel efficient a diesel is as well as people that understand it's a lot easier to run on biodiesel then it is to run on any type of bio gas such as ethanol. Example my mom runs a VW jetta TDI diesel she complained when it was only getting 54MPG running 65-70mph over mountains and contrast that to the wonderful hybrids that when operated within particular parameters adn keeping the speeds down MIGHT see 50mpg (or compared to the gas operated version of the same care that gets 30mpg) so yes diesel is higher but done properly diesel would have to be almost double the cost of gas for it to NOT be a wash let alone the fact that diesel powered vehicles even without epa mandated pollution controls are cleaner then even current gassers, and they can get the fuel economy and still have good power as well as typically they last much longer.
So yeah I can't see why anyone would want an engine that is 20-45% more efficient, 80% cleaner, over double the torque, usually 25% more power for the size and typically last 2-300% as long.
__________________
Optimist or Pessimist?
Optimist = Believes we live in the best possible of all worlds.
Pessimist = Fears this is true.
  #75 (permalink)
Old 05-27-2008, 01:46 AM
Thats awesome her VW gets 54mpg over mountains i'm happy thats fantastic. Her VW isn't a Truck! and where in the US can you find any of those things? Sure as heck can't find them here in Texas or 90% of the US for that matter.
They were going to build a huge E85 plant near the sate line here but the bottom dropped out of if.
Fuel cells are awesome but who cares only the rich will be able to afford a 80,000+ dollar grocery getter So ya who cares.
A Hydro conversion runs around 100grand and thats not counting the car/truck So ya Who cares.
And if you can afford to drop a months salary for a tank of fossil/Bio fuel for your Diesel that is 20-45% more efficient, 80% cleaner, over double the torque, usually 25% more power for the size and typically last 2-300% as long
then more power you to bud.
The only truth is, is that the end of the truck, SUV and large American car for the average American Joe/Sue is drawing near. So ya who cares. Just enjoy it before the only thing with wheels that a lot of us will be in is a buss.
__________________
NRA
TRSA
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
