Go Back   Ford Truck Enthusiasts Forums > Diesel > 4.4L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
4.4L Ford Diesel Discuss the much rumored 4.4L Ford diesel engine
Is F-150 Still King?
  #91 (permalink)
Old 06-03-2008, 06:46 PM
dkf's Avatar
dkf dkf is online now
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Quote:
Originally Posted by Lead Head View Post
$5000 will pay for it self in no time with the long oil change intervals, engine life, and higher mileage the diesel gets
Don't know how this turned into a gas vs diesel spiel, but I'll bite.
Its actually $6200 or $6800 if your getting a new diesel. Engine life isn't really a factor as the new diesels life expectancy is being reduced with the more power being rung out. OCI are the same with diesels as gassers 5k miles. Depends how you do the math, but today new truck to new truck there is zero advantage to going diesel (Well maybe a little more torque) especially since you can buy a Ford reman gasser for $3600.
Back to the origional topic and maybe this was answered, I just skimmed through and didn't read everything. How does Navistar have any basis to sue Ford over the 4.4l? Hasn't the 4.4l diesel been manufactured for several years for use across the pond?
  #92 (permalink)
Old 06-03-2008, 06:50 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Not necessarily. There are a couple of other advantages that I can think of that you would have by sticking with diesel. On it's face it doesn't look like diesels have their advantage anymore, but if you think outside the box, they still have a few surprises left in them.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #93 (permalink)
Old 06-03-2008, 11:10 PM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
200 ft lbs. is just a "little more torque"?
__________________
2004 E-450 6.0 139,000 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #94 (permalink)
Old 06-04-2008, 11:11 AM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
You can easily go 10,000 miles on diesels, it was the old oil acuated 7.3 and 6.0s that were really picky about oil, and you must not know much about diesel engines if you think life is reduce because of the increased power. The cummins 5.9 and 6.7 used in dodges have always been rated at 300,000 miles life to overhaul. Talking about an engine that started out with what? 170HP and how has 350HP, with still the same life expantancy.
Also, its not a little more torque, its over 200 ft-lbs more as it was said, at a much lower RPM. Peak 650 ft-lbs reached at 1600-2000 RPMs, instead of 360 ft-lbs @ 3600 RPM.
It doesn't matter that ford may have be using the diesel over seas, the agreement was that ford could not use an inhouse diesel in the F-150
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #95 (permalink)
Old 06-04-2008, 12:09 PM
dkf's Avatar
Recommended OCI isn't 10k miles. You can use a 10k OCI on pretty much any truck engine especially when utilizing synthetics, OA and aftermarket filtering systems. With over 200ft lbs more torque than a gasser, the performance difference is not that astoundingly different until you get high in altutude or approach the 18k GCWR range. Gearing needs to be right to accomadate the powerband of the engine. Torque on the 3V 6.8l is 457ft. lbs at 3250rpm. Seems the manufactuers are trying to spin diesels faster to get a more gasserlike powerband. I agree the diesel responds to modifications much better and is not as picky with fuel type as gasser, well at least prior to dpfs and more strict emmisions.
So the 7.3l and the 6.0l get about the same life expectancy before an overhaul?
A recommended at 300k miles service life isn't too far off from a gasser.
That sounds like a very unfair agreement between Ford and International, and was to internationals benefit. I think it would probably be cheaper for Ford if they could work with International to continue building engines vs spending big $$$ to build and retool a new facility especially with the current decline in truck sales. If Ford wants to make a go of this new 4.4l in the 1/2 ton it better yield impressive mpg and decent power #s or it is doomed from the start.
  #96 (permalink)
Old 06-04-2008, 04:11 PM
That sounds like a very unfair agreement between Ford and International, and was to internationals benefit. .
Remember Ford renegged on a deal with International around 2001-03 for the 4.5 V6 diesel to be used in SUVs and light trucks after International invested much money on its development, this exclusivity agreement may have been part of the settlement reached on that deal.
__________________
one EGR valve.
  #97 (permalink)
Old 06-04-2008, 07:42 PM
dkf's Avatar
Quote:
I remember hearing about it way back when and actually didn't recall it until you brought it up. Around 01' would have been a great time for Ford to release the 1/2 ton Diesel. The truck market is in a slump right now so I don't know how it will do.
  #98 (permalink)
Old 06-06-2008, 11:59 PM
northern 7.3 northern 7.3 is offline
Temporarily Deactivated
northern 7.3 is starting off with a positive reputation.
Toyota already showed a one ton at SEMA i believe it was with an 8.0L??? Hino Diesel. concept yes but.... never know.
  #99 (permalink)
Old 09-07-2008, 06:56 PM
daniel simonsen daniel simonsen is offline
daniel simonsen is starting off with a positive reputation.
the only motor that ford ever made that was built to last was the 300 i6 i wish ford would put in the time and reserch in these motors and use them v8 diesels are junk besides the old idi i have a 93 ford f 250 with the 300 i6 c6 trans 4.10 rear and it will pull my dads 6000 pound boat just as good as my 95 dodge ram cummins 12 valve no matter gas or diesel i think the i6 will always last the longest with least amount problems than the v8 motors they are not much on speed but they run smooth and dependable and thats what i think ford should put in the f 150s
  #100 (permalink)
Old 09-07-2008, 10:58 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
The 300 had its day but there comes a point where things need to be put out to pasture.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
http://mistercmk.com/images/sig.jpg
Quote:
Originally Posted by tcbofade
I have no brain
  #101 (permalink)
Old 10-06-2008, 02:10 PM
slomafarms slomafarms is offline
slomafarms is starting off with a positive reputation.
toyota and cat??? no!!!
there couldnt be anything worse
diesel power is the best mag out there...
  #102 (permalink)
Old 11-14-2008, 07:45 PM
smokin_h's Avatar
smokin_h smokin_h is offline
smokin_h is starting off with a positive reputation.
TOYOTA...its all simple here ill spell it out..."TOY"ota...even if they do have a diesel it will probably be a joke IMHO
  #103 (permalink)
Old 11-14-2008, 08:14 PM
tjc transport's Avatar
tjc transport tjc transport is online now
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
toy yoda has had a diesel division for years. it is called hino
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #104 (permalink)
Old 11-14-2008, 08:19 PM
smokin_h's Avatar
i know lol but it will probably be a joke if they put it in their junk trucks...who knows what ridiculous tv commercial they will make for it??
  #105 (permalink)
Old 11-14-2008, 08:50 PM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is starting off with a positive reputation.
The 8 liter Hino will not be a joke. especially if they hook it to the 7 speed manual they had at SEMA. Toyota has already taken a large market share of the light truck market with the Tacoma and then the Tundra. If they make a 1 ton duelie they will take that much more. I do hope Ford gets it together soon.
I really would like to buy a diesel SUV. The diesel F-150/Expedition seem to be on the shelf, Chevy has pushed back the mini Duramax Suburban back.......Hummmmm I would buy a Hino/Sequoia.
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4 moose lites
Mobil-1 Turbo diesel truck oil
fuel filters every 10,000 miles
AstroStart auto start
98 gal Transfer flow tank
Rhino liner on the rockers
Wabasto-Blue heat
MBRP turbo back duels w/ no CAT
Tags
2007 , 250 , 60 , 64l , diesel , drain , f150 , ford , lawsuit , lawsuits , oil , pan , pickup , plug , powerstroke , spec , torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
