New TSB for the 6.4
New TSB for the 6.4
This is from Pickuptrucks.com and is reguarding the 6.4 diesel.
Blue Oval News is reporting on a new technical service bulletin (TSB) that Ford Motor Company has issued for 2008 Ford Super Duty pickups with diesel engines.
According to the TSB, certain F-250, F-350, F-450 or F-550 models with 6.4-liter Power Stroke motors manufactured between April 3 to May 21, 2007 may have faulty fuel injectors in cylinders 1, 5 and 7 that need to be replaced with new units.
According to Ford spokesperson Wes Sherwood, the injectors were accidentally damaged during testing at the supplier's facilities, caused by human error setting up test equipment. The damaged injectors create a misfire condition that will cause the vehicle to run rough or hesitate, especially during acceleration.
About 3,000 engines have been impacted by the issue. The majority of those engines have either been corrected at the factory or are being corrected in dealer inventory. Approximately 250 engines are in customer hands and Ford has notified those owners of the TSB.
Mr. Sherwood says the fix requires a few hours to correct and that there is an ample supply of properly working injectors available to replace faulty units.
Originally Posted by rollerstud98
6.0 started with trucks coming off the trailer, being parked then needing a new motor right there
They know the serial #'s of the effected trucks and they should be able to tell by that...
Originally Posted by Enomra
Wrong!!!!!!!! The turbos may have gotten stuck by sitting on the lots but the engine was fine. They called this scenario (lot rot)....
Not that I am aware of. Most all of the problems relating to the early 6.0 where from programming and the sticky turbo issues. Most turbo issues where from lack of use like mine. I let it sit for several weeks between uses and the original turbos did not like that. The later and the replacement turbos have relief cuts in them to prevent them from sticking: problem solved!!!!!!!!!!!
did they not have an oiling problem right off the bat, ended up with a few siezed motors from that?
