Door Actuators
Old 06-13-2007, 09:24 AM
mollikate's Avatar
mollikate
mollikate is offline
Door Actuators
I Need Three Anybody Know Where A Deal On Them Is At?
Old 06-13-2007, 09:53 AM
empiretc's Avatar
empiretc
empiretc is offline
If you want stock, they are $50 a piece at the dealer.
Or, you can do what I did. Leave the stock ones there, and install these along with them. eBay Item number: 120130018768. I put these in a palce that's easy to get to so they will be real easy to replace if they ever fail.
Old 06-13-2007, 10:06 AM
WILDMAN_Stroker*7.3's Avatar
WILDMAN_Stroker*7.3
WILDMAN_Stroker*7.3 is offline
door actuator
So how would you install them and set them up to work without removing the old ones.
Old 06-13-2007, 10:17 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
If you have the time to do it, the "tin foil" fix really DOES work,
Two down, two to go. ;-))
Pop
Old 06-13-2007, 10:40 AM
vettdvr's Avatar
vettdvr
vettdvr is offline
Check the Tech Section for all the how to's. Jim
Old 06-13-2007, 10:47 AM
mollikate's Avatar
mollikate
More Guidance On Where To Get All This Info Please
Thanks
Old 06-13-2007, 10:49 AM
vettdvr's Avatar
vettdvr
vettdvr is offline
Old 06-13-2007, 10:56 AM
empiretc's Avatar
empiretc
empiretc is offline
Wire them with the existing actuator, mount them on the door, and tie the rods together. Its not hard. You could always got to any local car audio/alarm place and have them do it.
Old 06-13-2007, 10:58 AM
SpringerPop
Here's the thread on "tin foil":
https://www.ford-trucks.com/forums/4...or+locks+fixed
It's a no-cost fix that really works. I did two of mine over a year ago, and they still perform as-new.
I just need to do at least one more...
Pop
Old 06-13-2007, 11:24 AM
empiretc's Avatar
empiretc
empiretc is offline
i studying on the tin foil fix for a while, but after taking the door panel off and seeing where the actuator was at, I decided on plan b. I didnt want to risk breaking it by just trying to get it out.
Old 06-13-2007, 11:30 AM
SpringerPop
It's not a job for the ham-fisted.
Some pretty-small work once you get inside the little motor.
Just take your time, and don't start throwing things when it gets smaller than you can see.... ;-)))
Pop
Old 06-16-2007, 04:47 PM
vettdvr's Avatar
vettdvr
vettdvr is offline
Pop
Danged,, I thought that is when you checked to see if it would pass the FLING test. :-)
I usually repair the resistor by either using a $.01 copper piece the exact size or soldering a 18 gauge copper wire around one end. Both methods work and wont be subject to wear from vibration. Jim
Old 06-16-2007, 05:49 PM
nightskyisme's Avatar
nightskyisme
nightskyisme is offline
Ham fisted? I never laughed so hard, thanks for that Pop. The foil DOES work and they aren't too bad to get to.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Door Actuators
