HELP!!!!!! P0401 to P0402 - Ford Truck Enthusiasts Forums
Old 06-12-2007, 10:19 AM
bigbadben bigbadben is offline
bigbadben is starting off with a positive reputation.
A while back, I had the P0401 code come up on my 2001 Ford F-150 4.6 V-8.
The truck would sputter and surge at low speeds.
I searched on here for help and then did the following things:
Replaced the DPFE Switch
Replaced the EGR Valve
Removed and cleaned the Throttle Body. (Loads of carbon in the ports)
Replaced the Throttle Body Gasket
Replaced Spark Plugs
Replaced Fuel Filter
The truck ran fine for a day or two then started the surging again.
Then I got the CEL, and now this time, its P0402. I go from Insufficient Exhaust Gas Recirculation to Excessive. I am at my wits end. Im about to take it to a shop.
Any advise before I bite the bullet & put a big dent in my wallet?
Old 06-12-2007, 12:54 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Vacuum leak! Check the rubber elbow at the back of the intake manifold. Good luck!
Old 05-22-2008, 05:47 PM
cmbonandon cmbonandon is offline
cmbonandon is starting off with a positive reputation.
P0402
I am getting the P0402 code on my 2002 Ford F150. Yes it sputters sometimes at low speed. I changed the EGR and cleaned out all of that crap that throttle body. It worked for about 3000 miles and now it's back on and sputtering again. Vacuum leak? is that hard to get to? Is that gasket hard to get to. Becuase I too don't want to crap open the piggy bank. Please advise
Old 05-22-2008, 06:50 PM
scratchanddent scratchanddent is offline
scratchanddent is starting off with a positive reputation.
i have a 97 f150 4.6 doing the same sort of thing. p0402, stumbly/shaky engine performance. i have worked through most of the same fixes: clean throttle body, replace most of the egr parts, plugs, wires, etc.... i'm thinking of replacing the vacuum hoses throughout. still not sure if this is going to solve anything, does this code pop up from maf or o2 sensors? this sort of thing seems way too common for there to be so many gremlins to hunt down in these engines.....
Old 05-29-2008, 07:58 AM
beannerb beannerb is offline
beannerb is starting off with a positive reputation.
codes 401 402
I have a 97'ford f-150 4.6l gave me po401 po402 codes gave it smoke test and the iac idle air control was leaking jusr a suggestion that was after three trips to garage.
Old 05-29-2008, 06:10 PM
sheetsd66 sheetsd66 is offline
sheetsd66 is starting off with a positive reputation.
Sputtering and surging at low speeds sounds like a vacuum leak. Check the entire PCV circuit. The rubber elbow on the intake is the usual suspect, but the rubber connector on the PCV valve end deteriorates and causes problems, too.
Make sure the new DPFE you put on there was a genuine Ford/Motorcraft part and clean the carbon deposits from behind the throttle plate.
Will a leaking IAC valve throw a 0401/0402 code? I know a bad one will cause idle issues, but I never heard of it causing a code. That's a new one.
Old 05-30-2008, 06:50 PM
Lance1601 Lance1601 is offline
Lance1601 is starting off with a positive reputation.
Ditto on the Ford DPFE sensor.
Old 06-04-2008, 07:04 PM
eallanboggs eallanboggs is offline
eallanboggs is starting off with a positive reputation.
When a IAC fails it usually fails shut causing the engine to stall at idle. That's the opposite of a leak. What would cause excessive flow whether real or perceived. If the EGR valve is sticking open when not being commanded to open. Or is the DPFE could erroneously report that the EGR is flowing when it is not.
Old 06-04-2008, 09:21 PM
ubereal2's Avatar
ubereal2 ubereal2 is offline
ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.ubereal2 has a great reputation on FTE.
I've replaced IAC's before and they had problems on idle. Some wouldn't. My 01 F150 with the 4.6-v6 has had the DPFE replaced twice in 131.8k. The truck never missed a beat. Run like a new one. Just turned on the light. Didn't even effect my milage.
I don't remember the code number, but recently went thru a leaking upper intake manifold gasket. Turned on the "Check Engine" light, and went from atleast 400 miles on a tank of fuel, to 325 a tank. Yes it's been fixed.
Bob
Old 06-04-2008, 09:23 PM
ubereal2's Avatar
I don't remember codes, but that sounds like missfire code for cylnder's one and two......
Bob
Old 06-05-2008, 12:40 AM
Misfire is P0300 to P0308. P0300 is random whereas P0301 to P0308 are cylinder specific.
2000 F150 mredington 1997 - 2003 F150 5 12-04-2015 07:23 PM
6.0l EGR Valve removal FYI P0401 P0404 makuloco2000 6.0L Power Stroke Diesel 2 09-20-2013 07:11 AM
Need help with OBD-II Code 0401 then 0402 propellerhead Ranger & B-Series 6 06-14-2013 08:14 PM
P0402 code on a 2001 Ford Expedition 4.6L djones35 1997-2006 Expedition & Navigator 1 08-30-2012 01:22 AM
P0401 / P0402 deejdeej Ranger & B-Series 4 06-10-2010 09:51 PM
Tags
01, 1999, code, dpfe, escape, expedition, f150, ford, iac, p0401, p0402, po401, po402, replacing, sensor, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
