Surging at 2100rpm
Surging at 2100rpm
I have an 05 with a 6 spd trans. and in 2nd or 3rd gear at 2100 rpm the truck will surge. It is at the dealership right now and so far the ford hotline has had the mechanic change an oil check valve, clean egr valve, reprogram pcm and check/clean? vgt actuator with no luck.
The ford hotline is out of ideas. Any suggestions.
Mark
Mark
Originally Posted by a-rod
maybe the egr needs changed, Ive heard more than once that cleaning them doesnt always work. There known to cause surging.
I should note that it only surges while traveling at 2100 rpm. It doesn't surge if I accelerate past that point.
Originally Posted by Dsl_Burner
Its been unplugged since I bought the truck so I think it would be fine.
http://www.ford-trucks.com/tsb/fullt...hp?tsb=06-22-6
It could be an intermittant problem with a sensor that is not setting a code. Have the dealer give you a data logger to hook up and drive with, then the tech can look at real time driving data to help isolate and intermittant problem.
Originally Posted by blackhat620
This is the only TSB out on your particular issue
www.ford-trucks.com/tsb/fulltext/show_article.php?tsb=06-22-6
Thanks for all the replies.
Its not intermittant. It happens everytime I drive at a constant 2100 rpm in 2nd or 3rd gear. I checked out that tsb before I took it in for service.
05 F-350 cc XLT sb 6spd, Build date 08/04, 5" Pro-Comp lift, 4" magnaflow duals staight piped, bullydog tripledog w/outlook monitor, 35" Dick Cepek FC II, BD short throw shifter, Pioneer indash Dvd/navigation
Possibly but it does it stock as well. Also the tech reflashed the pcm so wouldn't that clear the pcm and then rewrite it?
Sorry to sound sarcasitic, but I have had the same problem at 1700 rpm or 65 mph since new. Ford flew two (2) Yes, that is correct, 2 engineers out her in 2004 to drive my truck. Still to this day the truck surges. They have replashed, replaced, cleaned, monitored and whatever the every piece and part on the truck, including the turbo. Nothing has helped. The latest reflash dropped my fuel mileage by 20%. Power sucks, and NOW, the truck surges at 1400 rpm or 50-55 mph.
I believe it is time to look at a dodge or GM!
well that dont sound good
You have to get some gauges if you want to play
you can unplug ICP sensor and drive it see if that helps
Have you had the DTC scanned recent maybe its threw a code by noww sounds like it been back to the dealer recently
Theres enough info out here now we should be able to figure it out but your going to need a Gauge
If the tech performed the Flash Update correctly and then let the truck idle for at least 5-minutes prior to driving then the PCM should be re-written with the latest FMC program. BullyDog still may be giving the PCM fits however, as the PCM as a constant learning strategy and with the newest flashes, the EBP sensor is ignored and the PCM determins the VGT strategy based solely on the MAP & MAF sensors.
djones35
1997-2006 Expedition & Navigator
08-30-2012 01:22 AM
saycheessee
09-03-2009 08:06 PM
Beachbumcook
05-29-2004 04:53 PM
