Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Illinois Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
  #1 (permalink)
Old 06-11-2007, 12:30 PM
mommyof2 mommyof2 is offline
Garage is empty, add now
mommyof2 is starting off with a positive reputation.
Unhappy starter grinding
my husbands 92 ford rangers starter went out (had a short in it,the truck worked fine before this) we replaced it (4 times ) all grind, the truck starts and runs its the starter just won't disengage,flywheel is 2 maybe 3 years old and appears fine,we just changed the cylinoid(we also tried a starter from some where else) so now we are thinking maybe a short somewhere maybe the ignition switch
  #2 (permalink)
Old 06-12-2007, 10:48 AM
slisty slisty is offline
slisty is gaining momentum as a positive member of FTE.
Check at the selinoid for the short.
__________________
2005 F250 SD, Lariat, crew cab, 4x4, 6.0L
4" Silverline Turbo back exhaust, SCT Xcal2, EGT temp Trans temp and boost gauges, Stage 2 intake, and other HMP mods.
Some call it a peace sign, I call it the foot print of the american chicken!
ILLINOIS Chapter Leader 2006 to Present.
  #3 (permalink)
Old 06-12-2007, 02:06 PM
we had it checked nothing wrong with that, he said maybe ignition switch
  #4 (permalink)
Old 06-12-2007, 10:51 PM
That could be. Hopeing someothers will chim in here to help you more.
__________________
  #5 (permalink)
Old 06-13-2007, 03:06 PM
Rev Den Rev Den is offline
Rev Den is starting off with a positive reputation.
Does the Ranger use a shim for the starter?
Rev
__________________
Want to support our troops? Stop buying those stupid yellow ribbons and donate to the USO!!
  #6 (permalink)
Old 06-13-2007, 04:40 PM
it never has but we put one on still the same we also just changed the ignition switch and of course nothing we give up and taking it somewhere,thanks anyway
  #7 (permalink)
Old 06-13-2007, 05:16 PM
Perhaps check for voltage at the starter after the engine starts?
voltage at the starter would indicate that it is still trying, and rule out the starter as an issue....then all you need to do it track back the voltage.
Rev
__________________
  #8 (permalink)
Old 06-14-2007, 06:43 PM
we figured it out, the cilinoid was wired wrong thanks for all the help
  #9 (permalink)
Old 06-15-2007, 02:01 PM
Glad to hear you found the trouble. We are all here help.
__________________
Tags
2006, 92, cylinoid, diesel, disengage, f250, ford, grinding, grinds, ignition, ranger, starter, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
