Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch, Transmission, Differential, Axle & Transfer Case
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-10-2007, 09:50 PM
JSPajak JSPajak is offline
Garage is empty, add now
JSPajak is starting off with a positive reputation.
C6 Modulator Adjustment
The previous owner of my 77 F-150 460/C6 2wd decided to adjust the modulator on the C6 transmission (newly rebuilt) to shift very quickly. At part throttle it's in 3rd at 20 MPH or less.
He did this in an ill-fated attempt to save gas.
I'd like to adjust it to more normal shift points at part throttle.
How do I do this?
__________________
John Pajak
Lexington Park, Maryland
61 F100 Unbody: http://i5.photobucket.com/albums/y190/jspajak/61_F100.jpg
77 F150
00 Excursion
http://jspajak.tripod.com
  #2 (permalink)
Old 06-10-2007, 11:01 PM
53fatfndr's Avatar
53fatfndr 53fatfndr is offline
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
Pull the vacuum line off of the modulator. When you look inside you should see a small slot that a screw driver will fit into. Use your flat screw driver and turn it clockwise to raise the shifting points, and counterclockwise for earlier shift points. From what you describe, you want clockwise turns. Don't turn it all the way in! Start with 1/4-1/2 circle turns, take it for a drive and see how you like it, and just fine tune it that way. Hope this helps.
__________________
Branden
'53 Ford F-100 Hot Rod
'79 F-350 4X4
'94 F-150 4X4
http://www.ford-trucks.com/user_gall...163821.520.390
  #3 (permalink)
Old 06-11-2007, 04:13 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
Some modulators don't have the adjustment screw. If yours doesn't have it pull the modulator and make or buy a longer pin for behind the modulator. Longer pin = later shifts shorter pin = earlier shifts.
Tags
460, adjust, adjusting, adjustment, ajust, c6, ford, line, location, modulator, points, shift, trans, transmission, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
