Clutch won't disengage ~ - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-10-2007, 06:58 PM
Snowbunny's Avatar
Snowbunny Snowbunny is offline
Snowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputationSnowbunny has a superb reputation
2002 F-250, 7.3L, 6 Speed, 97k miles ~
<o></o>I am 200 miles from home this morning and stop to get some fuel. I come to a stop, transmission in gear, clutch pedal on the floor and start creeping forward. I think I must be on a bit of a hill and step on the brake. The rear tires start spinning and the truck insists on forward motion. The clutch pedal will not come up off the floor, the stick will not come out of gear and I am burning out in the dirt. So, I shut off the ignition. I restart the truck and pry the clutch pedal off the floor with my toes. Put it in gear and go to parts house to top off hydraulic fluid ~ which was not low.
<o></o>Highway traveling was fine, not any problems shifting into 4<sup>th</sup>- 6<sup>th</sup>. The trouble came whenever I had to stop. So, I just throw it in neutral and coast, no biggy. Then the light turns green and she won’t go in gear or stay running. I have to all but start it in gear so we’re starting and going at the same time. Made for some busy driving.
<o>S</o>o, I realize that the clutch is not disengageing and the throw out bearing is not ‘throwing out’. The local dealer replaced throw out and pilot bearings in March along with input shaft and 1<sup>st</sup> -4<sup>th</sup> syncros. So, I will be taking it right back for some warranty work. My question is this ~ Is there anything I can do to ‘jerry~rig’ my truck so I can get it to Ford without mowing everybody over along the way?
Old 06-10-2007, 08:03 PM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
I'm not familiar with your setup, but if it has an adjustment rod associated with the hydraulic clutch, maybe you can "maladjust" the rod longer to compensate for clutch not disengaging properly until you can get it fixed.
Old 06-10-2007, 08:15 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Unfortunately there is no adjustment on the hydraulic assembly in your clutch. I'm afraid your only options are to either do what you've been doing or call a tow truck.
Old 06-10-2007, 08:21 PM
Snowbunny's Avatar
I was afraid of that... It's OK though, I got the rhythm down pat! Ha! Ha! We'll 'dance' our way to Ford tomorrow! Thanks!
Nik's 97 350 build thread nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 1336 01-31-2017 06:55 AM
1997 F250 4X4 Crew Cab Rear Spring Question 38-72 1987 - 1996 F150 & Larger F-Series Trucks 2 01-12-2012 11:12 PM
What the heck is going on inside my 460 38-72 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 17 11-03-2011 07:10 PM
4:30 gears 6.0l - towing results Red Ex Excursion - King of SUVs 12 03-30-2011 08:16 AM
203*Thermostats, Heat, and PSD Efficiency....The REST of the story! ernesteugene 1999 - 2003 7.3L Power Stroke Diesel 46 06-28-2007 11:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
