4r100 linkage adjustment
I'm in Modesto, Unfortunately I will be in New Orleans from the 16th thru mid
May. Yes My homebrew is drinkable. 5 1st places, 1 3rd, and 2 Best of Shows at the California State Fair. The 3rd was a stout that was the exact same beer
that took 1st as a Porter, and the 2 Best of Shows, (3yrs apart) were British Bitters. One Day I would love to come to a tech day and bring a keg, It just has to fit with my schedule. I'm learning Sooooo much on this forum. Again Thanks to all who participate and help out the less informed. Knowledge is King!!
If it's the dial that is off you can adjust the thumbwheel by the steering column. A white plastic bracket that held the thumbwheel in place broke on mine. I had to jury rig it with a bread tie.<a href=_blank"><img src="http://i842.photobucket.com/albums/zz345/Phubai68/thumbwheel002.jpg" border="0" alt="Photobucket"></a>
If the shift linkage feels sloppy follow the shift cable to where it attaches to the linkage on the steering column. The cable attached to an arm that is attached to the shaft inside the column with two torx screws. The screws loosen and will cause the indicator to be off. If the screws are loose, remove them one at a time, put a dab of loctite on the threads and re-install.
Reps given
Leeboy1962
02-23-2014 02:48 PM
iron1951
02-18-2011 06:39 PM
