Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-10-2007, 12:51 AM
Social Outcast
petes79f150 has a very good reputation on FTE.petes79f150 has a very good reputation on FTE.petes79f150 has a very good reputation on FTE.petes79f150 has a very good reputation on FTE.
Cam Break In Article
I posted this over in the Engine Building forum, and Eric thought it might be a good idea to post the link here too. Input from Barry R (Survival Motorsports and FTE) in an article in Hot Rod:
http://www.hotrod.com/techarticles/e...ech/index.html
Pete
__________________
The Hurrier I Go, The Behinder I Get.
Last edited by petes79f150 : 06-10-2007 at 12:57 AM. Reason: tried link, didn't work,so.......
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-13-2007, 05:05 AM
angus is starting off with a positive reputation.
Thanks for the link. A few weeks ago, a guy told me about this problem with old-style engines and the new oils. I looked around for info and didn't find much practical help, other than the GM EOS, or some flavour of STP oil treatment. Looking in the "snake oil" section of Canadian Tire, there was a Fram oil supplement that listed ZDDP as an ingredient.
I'll be looking for some of that Shell Rotella T; sounds like it has to be cheaper than buying regular oil and expensive snake oil supplements.
__________________
1957 panel delivery / 1959 M100 flareside / 1960 M100 styleside / 1960 panel delivery
  #3 (permalink)
Old 06-13-2007, 11:06 AM
horsepuller's Avatar
horsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant future
Good info. Thanks for sharing. We'll sticky it for a couple of days.
__________________
Scott
FTE Moderator
  #4 (permalink)
Old 06-29-2007, 10:20 AM
DarkWolf40's Avatar
DarkWolf40 is starting off with a positive reputation.
The guy that built my 410 recommended I add BG MOA for a source of zinc and specifically stated if I didn't use it the cam would probably fail.
  #5 (permalink)
Old 06-29-2007, 10:46 AM
arctic y block's Avatar
arctic y block has a very good reputation on FTE.arctic y block has a very good reputation on FTE.arctic y block has a very good reputation on FTE.
Remember to remove the outer spring during brake in as stated. I learned this the hard way and lost three cam's before I figured that out.
__________________
62 UNI Wide Window SWB 390 C6
66 F350 Flat Bed Hi Pro 427 4 speed
7 4X4 Rangers 84 thu 89
55 Fairlaine Town sedan 272 Ford O Matic
Alaska In Summer. Washington in winter.
Show all the luv ya can while ya can. Or one day ya may be alone
Don't just Modify it Fordifiy it
  #6 (permalink)
Old 06-29-2007, 12:48 PM
2000Expy's Avatar
2000Expy is gaining momentum as a positive member of FTE.
So does this apply to our vehicles?
__________________
2000 Expedition XLT 4x4
4.6L Triton engine
Bilstein shocks
16" Michelin X® Radial LT
Kenwood 10 CD-changer
Virginia Chapter
I'm never serious unless I should be.
  #7 (permalink)
Old 06-29-2007, 01:09 PM
Generally only on a high lift cam do ya need to remove the outer spring for brake in. My 390/427 (yes it had plenty of sleeve to make the bore) Wiped the lobs off two cams and broke the 3rd. All within 50 miles. Than I was told to remove the outer spring for brake in. The last one is still running in the 66 F350 after about 12 years. Don't use it but once or twice a year to haul a load of freight. But I start it every other month year round.
__________________
  #8 (permalink)
Old 07-05-2007, 05:56 AM
kermmydog's Avatar
ARIZONA CHAPTER MEMBER
kermmydog has a great reputation on FTE.kermmydog has a great reputation on FTE.kermmydog has a great reputation on FTE.kermmydog has a great reputation on FTE.kermmydog has a great reputation on FTE.
THANKS SO MUCH FOR THAT INFO. I have been wondering about this deal of a lot of complains about cam troubles. I even was talking with a friend about this. This explained the problems very well. I looking at rebuilding my 460 in the next year or so and this will help me make choices I in the past might not of made or thought of. Again thanks for sharing this with us.
  #9 (permalink)
Old 07-05-2007, 11:34 AM
jimandmandy is gaining momentum as a positive member of FTE.jimandmandy is gaining momentum as a positive member of FTE.
I just read a manual on converting auto engines to aircraft use. The author recommeds a mixture of STP and Rotella T for assembly lube and Rotella T as break in oil, for the cam lobes and lifter faces, a special lube from Crane Cams.
Aircraft oils, like Aeroshell, are "ashless" so contain no ZDDP. Cam and lifter damage on Lycomings have been a problem for years. There is an additive, tricresyl phosphate that is now required for some Lycomings. Oddly, it is not recommended for break in.
Jim
  #10 (permalink)
Old 07-05-2007, 09:34 PM
Rockledge's Avatar
Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.
I wonder if all these cam failures could (should?) have been anticipated in advance of the lowering of the zinc levels in motor oil. Was the automotive industry entirely ready for the most recent change? Doesn't sound like it to me.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #11 (permalink)
Old 07-06-2007, 10:47 AM
Quote:
The new car and truck makers are the ones that told the oil blenders to get the phosphorus (ZDDP) out, for emissions warranty reasons. Roller cams have been in Fords since about 1993. When was the last time you heard of such failures in a newer, stock engine, even running 5W-20? It is the automotive AFTERMARKET that was not ready, and has no power over the other, much bigger players. I also suspect poor materials or heat treatment may be partly at fault, that can be masked by really good boundary lubrication (ZDDP).
Jim
  #12 (permalink)
Old 07-07-2007, 03:05 AM
Rockledge's Avatar
Quote:
Jim
Good points as usual, Jim.
__________________
Ford Pics
  #13 (permalink)
Old 07-08-2007, 07:47 AM
pawpaw has a good reputation on FTE.pawpaw has a good reputation on FTE.
Seems to me, If the new SM GF-4 oil says it's backwards compatable with previous "S" ratngs, wouldn't we be ok in most cases, as they can formulate other barrier lubes into the recipe, to take the place of the inexpensive ZDDP.
I mean surely there are other barrier lubes that can do the job, maybe they are a little more costly, or maybe they are more difficult to blend in, or somethng, but for most of us with normal profile lift, non roller or follower cam engines, shouldn't we be ok with those lubes that state they are backward compatable with previous "S" ratings????
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles, but trifles make perfection & perfection is no trifle (Ben Franklin)
Your signature is a sign of a job completed, autograph your work with excellence
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
